Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Engine cutting out!! Exhaust emissions warning light! Help!
    London
    confused Engine cutting out!! Exhaust emissions warning light! Help!
    Hi all,
    A couple of days ago the exhaust emissions warning light came on while driving (constant not flashing) , instantly followed by the rev counter dropping with complete loss of power (including power steering) and then the red battery symbol came on. Coasted to the side of road and tried to re-start but nothing happened (starter motor not even turning over) so waited about 30seconds and tried again. This time it starts fine but the exhaust emissions warning light stays on and I drive home without any problems.
    The next day it starts fine again and no warning light but...
    Yesterday the exact same thing happened again TWICE in one (short) journey and again today. I usually have to wait around 30secs to a minute before re-starting. The warning light seems to stay on for next couple of re-starts but will eventually go away.
    Will be booking in to the garage as soon as I can but was hoping that someone could shed some light on why this might be happening??
    Thanks in advance
    Oh its a 52 plate 2.2 petrol if thats any help. Cheers
    Gävle, Sweden
    As it's a petrol, I suspect the high pressure fuel pump. I had mine replaced last week...
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by stryker99 View Post
    Hi mate
    Only 04 or 54 onwards have a high pressure fuel pump his engine is a Z22SE so his does not have one the previous model
    Ours is a Z22YH which is Direct injection the one with the High pressure fuel pump
    Apr 2008
    Liverpool
    Quote Originally Posted by jde1 View Post
    Hi all,
    Thanks in advance
    Hi mate Rushy might know more about this im sure he will be on in a bit hes somthing of a expert on your engine
    London
    Thanks for the reply. I had it in the garage last week and they couldn't find any fault codes! Sod's law that on the way to the garage it was fine and no warning lights were on so when they plugged the machine in it told them nothing. Got home from the garage fine as well. But last night it happened again five times in a row!! Had to get breakdown truck out to carry me home!
    The breakdown guy mentioned it might be the lamda sensor but not sure. It's going back to the garage today.
    Full Member Big Sig's Avatar
    Quote Originally Posted by Sean-2.2Direct View Post
    Hi mate
    Unless its a signum which all of the 2.2's were directs
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If it has a habbit of cutting out at idle I would suggest egr valve needs cleaned. That was the same symptoms on our 1.6 corsa, emmissions light was on, and car would judder at idle and occasionally cut out.
    Gazza4
    London
    I also had the judder problem and it would 'hunt' between 5000 and 10000 revs at times but while it was in last week it had a service and they also cleaned out the throttle body and breathers (whatever they are!) because they were carbonised apparently. It now idles at a solid 7000ish with no judder. Seems a bit more responsive too when its not dying on me!
    It's a 2.2i 16v Elite if that makes any difference.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The emissions light is could also be indicating a catalytic convertor issue.
    Only way to check for this is to have an emission check.
    Gazza4
    London
    So... just got a call from the garage and apparently the error code is p0601 which means an internal ECU fault! They are now asking for £579 for a new ECU unit!!! Grrrr!!
    Any ideas of how I can avoid this would be greatly appreciated??
  1. Emissions warning light on
    By peterb11 in forum Engine & Drivetrain
    Last Post: 18th March 2011, 17:03
  2. Emissions Warning Light
    By fifesri in forum Engine & Drivetrain
    Last Post: 14th September 2010, 20:58
  3. Emissions Warning Light
    By Electricdave in forum Electrical & ICE (including SatNav)
    Last Post: 2nd September 2010, 21:12
  4. Engine/Emissions warning light
    By MultiDropper in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2010, 14:23
  5. Replies: 1
    Last Post: 1st September 2007, 12:17
vectra exhaust cuts out engine
Tags for this Thread
