Thread: AirCon queries
    Vale of Glamorgan
    Default AirCon queries
    I had my aircon regassed a couple of weeks ago and since then its been icey cold in the cabin. Yesterday I went out for a few minutes and it was icey still but today while its cold its not as icy as yesterday. Does the aircon take a few minutes to warm up/cool down ie engine needs to be runnhing for 10mins etc?
    If not I guess I have a problem with the air con somewhere. Is aircon covered by warranty? Ive got 500 miles left to get any niggles sorted at the stealers under warranty.
    advice appreciated.
    Jim
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    the aircin needs to be running a while before the full benefits can be obtained
    keep an eye on it as well... might have a leak in the system.
    Surrey
    Use the re-circ button.
    Regular Member barkzz's Avatar
    Quote Originally Posted by Jim2k View Post
    advice appreciated.
    Jim
    The air con can take 5-10 mins to get to its coolest temperature.
    If you have a leak in the system, you will notice it taking longer and longer to get cooler, and eventually it wont even get cool.
    If that happens, its more than likely your seals are shot.
    The vast majority of the air con components arent covered under warranty, i know the gas/seals/condensor definately arent
    Vale of Glamorgan
    Thaks for the feedback guys. Will give it a blast tomorrow on the half hour journeyto work and see what it does. Hopefully it just needs a warm up.
    Regular Member mcwharam's Avatar
    Oct 2007
    Leeds
    I've had my aircon regassed twice at Charlie Browns twice in the last 8 days. In between the car has been in for the clutch and flywheel doing.
    The aircon was nice and cool for 3 days before the car went in for the clutch doing. Didn't use the car for a couple of days and then on Sunday the aircon would not cool at all. I took it back to Charlie Browns yesterday and they recharged the system. They said the gas was still in there, but none the less let it run through their program to recharge (no leaks found).
    This morning the aircon was fine - came out at 11.00 am from work and it will not cool no matter how long I leave it on (+ 35 minutes)
    The car is back in the Dealers again this Thursday as the car is a pig to drive due to clutch (1st and reverse gears are shocking to get in when warm). Where should I point them in relation to the aircon - which part is likely to be working intermittingly.
    Thanks for any help
    Martin
    Regular Member mattDY57's Avatar
    Yorkshire
    My aircon totally packed up over weekend. Compressor isnt even coming on. Cars only 20 months old. Another thing to add to the list when it goes to the dealers next week.
    Quote Originally Posted by mattDY57 View Post
    Could be due to the low pressure i.e. no gas in there.
    That will prevent the compressor kicking in to prevent any damage.
  1. Sat nav queries
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2012, 17:08
  2. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  3. Help with queries.
    By weverall in forum Styling
    Last Post: 4th January 2012, 01:52
  4. Few Queries
    By Adam B in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2010, 01:27
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
