Thread: Problem with Electrically adjustabale front seats
    Hamilton, New Zealand
    Default Problem with Electrically adjustabale front seats
    The drivers side front seat has stopped working when trying to adjust the seat positions (height, back, and forward/backwards), via the switches on the out side of the seats, or by the memory presets. The passenger side is working fine.
    The position memory is also not working as it will not adjust the mirrors. So i assume that it maybe a fuse, i have check fuses 3 and 5 at the rear of the car and they seem ok, is there another fuse that i should be checking? or can some one offer me some advice what maybe wrong?
    The manual talks about an overload and the power supply is automatically cut off for a short time, how is this reset and is there away for checking this or manually resetting it?
    Thanks for your help
    Oct 2006
    Wellingborough
    I'd try disconnecting the battery for half hour or so. also, can you still adjust the mirrors and open/close the drivers window? the seat works in conjuction with a module in the drivers door.
    Have you placed anything under the drivers seat (shopping etc) which could have snagged a cable? is the heating function still working?
    [Ex]Admin Duncan's Avatar
    I'd check the connection to the module under the seat first in case it's somehow managed to work slightly loose. Then start looking at fuses. I don't know what fuses relate to the electric seats but you manual will tell you.
    Quote Originally Posted by Flaninacupboard View Post
    Thanks for your help, the windows mirrors etc all work fine, so I disconnected the battery and this has fixed the problem.
    Oct 2006
    Wellingborough
    Excellent, hope it's a one off then!
  1. Heated leather/electric seats problem
    By dshelton999 in forum Bodywork & Interior
    Last Post: 27th January 2013, 13:51
  2. what are the downsides of electrically disconnecting EGR valve on the 150 CDTi
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2012, 12:46
  3. One for you electrically minded...
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2009, 00:59
  4. Electrically Folding Door Mirrors?
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 16:32
  5. Replies: 8
    Last Post: 27th January 2007, 22:02
