Results 1 to 10 of 15
Thread: dealer spilt brake fluid on car
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    Angry dealer spilt brake fluid on car
    I have a bit of a problem how do i go about this. i had my car in to the dealers for a major service today and had my brake fluid changed every thing went well, until this evening i decided to wash the car i know evey scratch etc on the body work then i noticed what looked as though some thing had been driped on the top of the o/s front wing it looked still wet.
    However when i rubbed it with my mitt it started to peel off then i realised that brake fluid had been spilt when they did the change Where do i stand on this in terms of a claim i know that this was done today and not been there before.
    all be it that its only a small drip and some in the inner part of the wing. what will be my next step.
    will they try and fob me off and say that it was allready there and i know for certain it wasnt.
    im a bit peeved off about this as i have a feeling they will try and fob me off.
    any advice on the above will be great
    cheers Craig
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    by the sounds of things they have spilt it all the way from the resevoire which in my eyes gives them no ground to stand on and depending on the car's mileage this could well be the car's first fluid change which further more helps your case. just take the car down to them and tell them what has happened,see what they say and if they refuse work take some pics and pop down to ur local citizens advice bureu.hth
    Apr 2006
    Quote Originally Posted by wanna veccy View Post
    Cheers wanna
    the car is a 56 plate ive only had it since August last year so dont know if the fluid has been changed before but i know that they have spilt the fluid without a dowt today
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    Just reason with them mate, go down and let them see the damage, they are not stupid, they will know your car was in for a service and coincidentally lost some paint due to a substance perishing the finish, try and do a deal i.e sort it out or your name is S*!T
    Regular Member Bloicy 3.2 V6 GSI's Avatar
    Aberdeen
    I would go back and raise your concerns. In any case any decent garage should be putting wing protectors on when working under the bonnent as standad as you would with seat cover, steering wheel cover and paper mats. It annoys me when you pick your car up and there's oily finger prints on your bonnet etc. Good Luck!
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Also take some photos
    Oct 2006
    Wellingborough
    If the paint has come away it's obviously fresh, as it will pretty quickly rust up.
    Apr 2006
    Thanks every one for the advice and on what to do
    Ive take a good amount of photos quite clear as well, so im going in to the dealers tomorrow to have the chat with the service manager fingers crossed they wont fob me off. ill go ape if they do
    Thanks again
    Craig
    Regular Member badback's Avatar
    Runcorn
    Don't let them fob you of mate, it seems to me it's their fault, they should fix it.
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
  1. Brake Fluid
    By gaz1965 in forum Comedy & Humour
    Last Post: 20th January 2013, 10:36
  2. Brake fluid
    By ed taylor in forum General Chat
    Last Post: 8th July 2012, 06:09
  3. Dot 5.1 and Dot 4 Brake Fluid
    By smitd004 in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2011, 12:36
  4. Brake Fluid Q
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 11:29
  5. brake fluid
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2011, 12:41
