Results 1 to 10 of 13
Thread: quick quest for science boffins
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default quick quest for science boffins
    If a car uses X amount of extra fuel with the windows down at 70mph and Air Con uses extra fuel due to pump.
    Which is actually cheaper.
    Not like im tight I was just curious are modern a/c pumps better for fuel consumption than older ones from the 90's??
    Full Member AL21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    5 Post(s)
    Vehicle : Toyota Aygo
    Trim : x-pression x-wave (nav)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    If i remember rightly, Mythbusters (discovery channel) did such a test, i seem to remember the windows down was cheaper.
    AL
    mythbusters. they think of everything lol.
    Thanks to them I know another fact, much like jumping in a falling lift wil not save buster nor me lol.
    Thanks al
    Jun 2007
    5 Post(s)
    Engine : 1.0 VVT-i
    Year : 66
    Mileage : 8000
    Not a problem
    AL
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    Mythbusters Geek here!
    They found out up to 56mph its cheaper with ALL the windows down. after that the drag of having the windows down superseeds the fuel the A/C on max uses. so if your on the duel carriage or motorway then use the aircon if just pootling then use the Windows.
    (still i prefer the windows open to the Air con anyday!) just a nice feeling with the wind blowing in
    Edinburgh
    AC vs. Windows Down
    Adam and Jamie tackle not so much a myth as what they call an "urban puzzle". The debate arises because both methods of cooling influence a car's fuel efficiency—air conditioning requires a lot of power to run, but at the same time, open windows create drag.
    Revisited in MythBusters Revisited, Season 3, episode 38
    Myth statement Status Notes
    Running a car with air conditioning on is more fuel efficient than running with the windows down. Partly Busted Tests were performed under varying conditions (55 miles per hour (89 km/h) versus 45 miles per hour (72 km/h)). Also, the 55 mph test was using a computer to estimate fuel efficiency based on air intake, not actual fuel consumption, and showed A/C was more efficient. The 45 mph test consisted of running the tank until it was empty, and showed open windows were more efficient. This experiment—or one like it—is sometimes cited by the Magliozzi Brothers on Car Talk when presented with this question.
    Should be noted it's taken from wikipedia (lol)
    The fundamental flaw in the MythBusters' test was that the point where the drag becomes powerful enough to inhibit a car's performance with windows down was inside their 45–55mph margin at 50mph. Going less than 50mph it is more efficient to leave your windows down, but going greater than 50mph it is more efficient to use your A/C.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    i would rather have the a/c on,and i think you will find the mythbuster are busted,they tend to use big v8 cars and their figures may be correct,as to our smaller cars you may find there will be a difference and as the drag is increased as you go faster and our smaller cars are more aerodynamic the speed will be a lot lower as the windows down will increase drag more
    Oct 2006
    Wellingborough
    also, who uses A/C on "Full"? i know with mine the compressor is not on that often unless it's a very hot day.
    Oct 2006
    southampton
    15 Post(s)
    my air-con is on all the time, sod the cost, comfort wins..
    well i was under the impression eco mode didnt put any ac on at all, i tend to leave mine on full auto set at 16 - 20'C. c/c is easier to set and forget about lol.
  1. remap science mobile remaps 2.0t
    By tomo41 in forum Petrol Engine related
    Last Post: 11th June 2011, 12:34
  2. Anyone ever used Remap Science in Bradford?
    By LeeU in forum Diesel Engine related
    Last Post: 3rd February 2011, 02:25
  3. This could be one for the 3.0cdti boffins..
    By riverdees in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 22:46
  4. Comp boffins - HELP!!!
    By mc_orion in forum General Chat
    Last Post: 29th February 2008, 22:51
  5. computer boffins
    By signumT in forum General Chat
    Last Post: 13th August 2005, 21:29
