Thread: FAO adfrodsham, re: 3.2 on NOS
    Regular Member muffking's Avatar
    Default FAO adfrodsham, re: 3.2 on NOS
    Adam, in response to your text, here are a few pics of when I ran NOS on my Vec.
    It was a Wizards of Nos kit who are based in Doncaster and run the forum at http://www.noswizard.com/
    The kit was good for an extra 100bhp, which I'm thinking is your backup plan to going the supercharger route?
    I may have more pics from when it was on my Vec B GSi, but the reason I took it off the Vec C GSi was due to the fact that I needed to change to Iridium plugs to run more power, but couldn't change them so I sold it, although you don't have that problem
    Regular Member AdeyCorp's Avatar
    Chesterfield
    Very nice, I woundered if someone has tried this. So with the how was it turned on? Button for when you had the pedal to the floor?
    Basically yes.
    There's a main ON/OFF switch, but also a switch activated when you press the pedal to the floor which I had running from the Throttle Position Sensor on the cars throttle body.
    Chesterfield
    Very nice, so couldnt the engine cope with it?
    The engine itself was ok, although the clutch was struggling off the line a little, but the main problem for me was that standard plugs cause problems over 50hp and they are very hard to change on the 3.2, so I didn't bother and sold up. I still miss the power though
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    So is that one of the progressive NOS or Power when needed in one big 100hp wack?
    Loving it BTW ha ha
    Definately progressive, that's the only way I ran 100hp jets in a V6.
    It did quite well in my old V6 though as you can see in the next pic, which is a screen grab of a video taken at Avon Park Raceway. I thought to get a 2.5 Vectra estate to do the quarter mile on road tyres in under 15 seconds wasn't bad.
