Thread: Interemittant non starter - 2.2 direct petrol
    11 Post(s)
    Default Interemittant non starter - 2.2 direct petrol
    Car is a 2006 auto 2.2 direct petrol Vectra Elite.
    Last night within 5 yards of pulling away the car cut out. Refused to restart, just cranking over and over. Car/spanner light was lit (but that's from a previous fault and goes out when the engine is running - so only indicating a stored code). In fact it went out while I was cranking the engine over last night.
    Got out, looked under the bonnet at the mass of plastic covering the engine and hastily shut it again. Tried to restart, still refused.
    I then locked and unlocked the car, and bingo it started. However 20 yards down the road the same thing happened. Just cut out, no spluttering beforehand, just died. Again refused to start until I opened the drivers door, closed it, locked it with the remote, then unlocked it, opened the door again and closed it. It continued playing up 3 or 4 more times, then ran right as rain after that. Initially the car/spanner light was on when the engine was running, then it went out and stayed out.
    Got home, turned the engine off. Started up again with no dramas. Car/spanner light remains on until the engine is running, which I know is indicating a stored fault code.
    I tried the pedal trick, both when the light remained on with the engine running, and when it only stayed lit until the engine is running. Didn't work, so was unable to flash up any fault codes.
    Luckily the car is in on Monday for a service & MOT. Will get them to look while I still have 2 or 3 weeks warranty remaining.
    In the meantime, does anyone have any idea why the car cut out, then refused to start until I locked and unlocked the doors? Car spanner light wasn't flashing, so I don't think it was immobiliser related.
    I know ultimately the fault code *should* reveal the problem, but in the meantime.....
    11 Post(s)
    Just been out in the car and it hasn't missed a beat. Being very cautious at junctions at the moment in case it cuts out as I pull out. Making sure the road is totally clear beforehand.
    Will have to see what the dealer says on Monday as no suggestions have come forward yet.
    Hope you get a result let us know what they find ................
    Bradford
    Trim : Elite Auto
    Engine : 2.2 Direct Petrol
    Same car as mine.... Please do let us know what the problem was....
    11 Post(s)
    UPDATE.
    Just had the garage on the phone. Fault code P1191 - fuel pressure low. They're gonna fit a new fuel pump & regulator as advised by Vauxhall because fitting only one or the other could still lead to complications.
    Fuel pump alone is £375. Fortunately the car is still under warranty until the 5th July.
    On a more positive note, the car sailed through the MOT without any problems.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Ahh the Dreaded fuel pump pray you dont get that fault when out of warranty glad its sorted and your through your mot
  1. which parts of a 2.2 petrol direct duel exit exit will fit a 1.8 petrol?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 10:25
  2. 2.2 petrol direct
    By markj23 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2010, 00:29
  3. 2.2 direct petrol HELP?
    By cturner89 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 22:39
  4. Vectra C, 2.2 direct, power loss- reluctant starter
    By Trebor_Lien in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2009, 22:59
  5. sri 2.2 direct petrol
    By topgun in forum Petrol Engine related
    Last Post: 17th June 2008, 11:05
