Thread: plugs or coil pack help!!!!!!!
    manchester
    Default plugs or coil pack help!!!!!!!
    emmisions light came on,took it to local freindly garage who plugged in(free of charge)and said misfire on cyl 4 plugs or coil pack any ideas many thanks rick
    Change the plugs first as its cheaper
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Or as a driveway check.... swap the plugs round so the one that's currently in cyl 4 is say in cyl 1. If the misfire moves (assuming there's nothing obviously wrong with the 4 plug when you remove it) then it's most likely the plug that's at fault.
    May 2008
    Derbyshire (south)
    I would say plugs too, if it was the coilpack then it would all pack up, not just on one cyl.
    manchester
    you all seem to be right,had the plugs changed,£25.00 fitted(ngk) if that means anything to you,been more smooth for some reason,done the job,see how it goes for a couple of days,fingers crossed,thank for help. rick
    Jun 2009
    South West
    Diagnostics can not read faulty plugs as they are not electronic if it was a plug it would say nothing. . If diagnotics say missfire 3 cyd it must be coil pack. Mitch coil packs can break down one cyd by one.
    manchester
    whats the best coil pack to get cheers
    May 2008
    Derbyshire (south)
    Glad its all sorted now mate. Not a bad price for the swap either.
    I have to bow to your better knowledge on the coilpack bigdar, as i have only heard of ones that just totally pack up.
  1. New coil pack or Plugs
    By Niall83 in forum Engine & Drivetrain
    Last Post: 23rd June 2012, 20:36
  2. Check coil pack/spark plugs Signum 2.2 direct
    By siross69 in forum Engine & Drivetrain
    Last Post: 17th May 2012, 15:00
  3. Spark plugs and coil pack
    By pogvec in forum Engine & Drivetrain
    Last Post: 17th February 2012, 22:23
  4. Coil Pack & Plugs
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2012, 23:43
  5. Spark plugs, coil pack and rocker cover gasket
    By ridgers84 in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2012, 19:12
