Results 1 to 10 of 14
Thread: annoying knock
    Regular Member denzilbud's Avatar
    cambridge
    Default annoying knock
    hi all my vectra sri has developed a knocking noise from the rear,doesnt happen all the time only when you go down bumpy un kept roads could this be the rear bush's if it is can someone give me an idea of how much it should cost to do both front and rears.cheers
    BRIZE NORTON
    Sounds like the role bar bush. They are only a couple of quid from the dealers and are a doddle to change.
    Regular Member zazaszazas's Avatar
    Cumbria
    the rear arb bushes will cost u £8 dunno about the front but shouldn't be more than a tenner
    cambridge
    thankyou both for the replys dont suppose theres been a how to on this has there
    Regular Member adfrodsham's Avatar
    lincoln
    ive just got to squeeze this in, but welcome to the world of vectra c, the home of annoying knocks
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Regular Member addyboy1982's Avatar
    Northampton
    Quote Originally Posted by adfrodsham View Post
    And welcome denzilbud
    cambridge
    cheers guys
    BRIZE NORTON
    No real need for a how 2 mate. The rears are just a single bolt and a half circle clip. Jack up the rear and remove the wheel, If you find the role bar at the back of the hub and follow it round you will find the bush its a piece of rubber with a spilt so you can remove and fit. They are 19mm for the sri, 18mm for the cop cars and 17mm for all other vectras. this is from my local Vx so worth checking what size you have. Its quite obvious how to change them over just unbolt and lift the retainer up and out a bit of wd-40 makes it nice and easy, i also used a bottle jack to lift the hub up to make it easier to re-fit and undo. Once done your knocking should be no more....
    Halifax
    A vectra is female becouse it has nockers o0
    Welcome to the nock nock whos there? club
  1. Help Needed Please...Knock knock...
    By wishy1976 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:34
  2. Knock, Knock, Knocking...
    By Carmaduk in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2011, 22:20
  3. Knock Knock whos' there
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2009, 21:18
  4. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
  5. Don,t knock the NHS
    By ed taylor in forum The 'Off Topic' room
    Last Post: 3rd March 2008, 19:49
