Thread: Condensation in headlight
    Kent
    Default Condensation in headlight
    Hi all, I have condensation in my nearside headlight. I have left all the interior covers off during a hot day to try and dry the ****** out, and this seemed to work as it had all cleared...... Or so I Thought cause the next morning , it was back!!!!!!
    Anyone any top tips on how to resolve this?
    North Yorkshire
    Assuming there wasn't another cause for the water getting in there again, then you did not get it all out. It evaporated into the warm air and cleared and then just condensed out again when it went cold.
    Do the same again. Take the covers off and let it all evaporate. Then change the air by blowing it with an air line, or get the vacuum cleaner up to one of the openings and suck the moist air out.
    Reassemble and it should be OK.
    You can just do the same on a windy day, and they usually clear, as the air gets changed.
    Newcastle under Lyme
    Hairdryer for a while and then some silica gel packets taped together stuck inside.
    Also remove the rear twist caps and you will see a foam seal inside the rim. Take this out carefully squirt some sealant in the groove and replace the foam seal squashing it into place. Leave to dry and then replace onto the light.
    Then stick a couple of those silica gel packs in there to absorb any moisture
    Kent
    Chers, tried this today, will see later after the temp goes down>>>>>>>>>>>>>>>>>>>>
  1. Headlight condensation
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 13:25
  2. Headlight condensation
    By Governor in forum Bodywork & Interior
    Last Post: 5th December 2011, 10:17
  3. Condensation in Headlight
    By cornishpirate in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2008, 15:48
  4. condensation in headlight
    By johnny kebab in forum General Chat
    Last Post: 11th October 2007, 17:10
  5. Condensation in Headlight!
    By Robbie in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2007, 17:11
