Thread: Rusty Torx Bolts & Screws
    Regular Member Hedgehog70's Avatar
    Yorkshire
    Default Rusty Torx Bolts & Screws
    Am I just unlucky or does anybody else have an issue with some of the Torx bolts and screw rusting badly (especially in the engine bay)? Some are still like new whilst others are badly corroded - I have had to replace all the ones on the air box already (No part number on system and cost me £2.65 each)
    TONY
    It's always got me for many years why screws & bolts rust next to each other, one bright as the day it was made the other snaps off rusted through ............
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    nope, all mine are like new.....except for the one under the door handles
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    Quote Originally Posted by Tadpole View Post
    Probably using cheap rubbish,I have seen boxes of new screws and some are not great,before they even go unto the car
    Regular Member collow123's Avatar
    cumnock ayrshire
    After reading your post i checked mine and the bolts at the airbox are also really rusted where as nearly all others are mint .... I wonder if others are the same???? Seems strange
    Regular Member crabbitoldgit's Avatar
    Wetherby (Body) - Ayrshire (Heart)
    If you want to spruce up your rusty bolts then try the following. Remove the rusty bolts, give them a quick scrub with a wire brush then heat them up with a blow torch. When they are glowing red drop them into a glass jar or metal tin containing some used engine oil. When they cool down you will be the proud owner of some nice shiny black rust free bolts. I learnt this trick from someone down at the local airgun club.
    May 2008
    Derbyshire (south)
    Quote Originally Posted by crabbitoldgit View Post
    Thats a cool wee thing to learn!!
    Can i just say that while heating these up, don't hold them with bear fingers.
    Use some pliers with protective handles.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by mitch1965 View Post
    Mate you shouldn't be using "bear" fingers to hold anything - chopping off a bear's fingers just so you can use them as a holding implement is cruel and some bear species are protected by international law.
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    the worst ones I have come across were the last 2 in the wheel arch when I was removing the front bumper....took 1 hour to remove them
    May 2008
    Derbyshire (south)
    Lmao!!
  1. Torx screws!
    By larrysSRI in forum Bodywork & Interior
    Last Post: 19th April 2012, 15:57
  2. Torx screws in wheel arches !
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 21:53
  3. Airbox Torx screws - all 5 vital?
    By RykuZ0 in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2007, 11:00
