Results 1 to 10 of 11
Thread: Tyre Pressure advice!
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Tyre Pressure advice!
    We are off on a 300 miles+ trip on Monday to Gatwick and the car will be full and have 4 suitcases in the boot so im conscious to get the tyre pressure right, i normally fill to 32 PSI, do i stick with that or make any changes this time given the heavy load? (120-8v)
    Steve
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Have you got a handbook - page 300 onwards. Higher than 32 I think. And depends on your tyre size.
    Regular Member old cruiser's Avatar
    slough
    To be honest mate if it were me I would raise up the tyre pressures, especially given the distance you're doing.
    Cheers Pete
    May 2008
    Derbyshire (south)
    I am sure with a full load its 36psi in the front & 40psi in the rear, fully loaded.
    Quote Originally Posted by mitch1965 View Post
    I am sure with a full load its 36psi in the front & 401psi in the rear, fully loaded.
    May 2008
    Derbyshire (south)
    Oops my bad!! It would save a bit on fuel though!!
    Regular Member BoroDave74's Avatar
    Attleborough
    Quote Originally Posted by BoroDave74 View Post
    Can you tell me what engine it is for a 120 8v?
    Attleborough
    Z19DTH I believe, I hope so I'm 120 8v too, but if I'm wrong someone will be along in a mo to correct.
    However, most petrol station tpg's aren't too accurate even if they comply with the current British Standard.
    Overinflate your fronts to 38 or so then deflate to 35, then rears to 46 and deflate to 42, if your on bog standard tyre sizes. That'll be as close as need be without using a UKAS calibrated master gauge.
    I've been running mine of the ECO setting for a couple of thousand miles and I pick a couple of mpg up that I've dropped since stopping using Millers.
    Thanks everyone for all the help will try that boroDave74
    Steve
  1. Tyre Pressure?
    By Knuckle in forum Suspension, Wheels & Brakes
    Last Post: 31st May 2011, 07:21
  2. Tyre Pressure Help ??????????????/
    By 3.2wales in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2009, 14:46
  3. Tyre pressure advice please
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2008, 19:57
  4. Tyre pressure
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 18:41
  5. Tyre pressure
    By skinnyseand in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2007, 19:10
