Thread: Rain sensor activation
    jilava
    Default Rain sensor activation
    Hi, I'm trying to activate the rain sensor with an OP-com interface and need help
    When I bought the car the rain sensor was not working, the control was on manual operation. I found out that the windscreen was changed and I think the previous owner had some troubles with the sensor and deactivated it. I am trying to troubleshoot the problem but can't manage to enable the damn thing.
    I know the sensor is located in the REC (Rear Electrical Centre) ECU but don't see any option for enabling it. I tried the "Program REC" button, entered the security code and nothing happened I would have tried the "reset REC" button but I don't really know what this does and didn't want to ruin anything.
    Attachment 22386
    I find it strange that in the measuring blocks menu there are lines instead of values:
    Attachment 22385
    Help please!
    [Ex]Admin Duncan's Avatar
    Is your version of Op-Com a legitimate one i.e. not a copy. Where did you get it from and what did it cost?
    If it's a copy then this is the problem with such - you'll find that they don't always function fully like the legitimate versions do.
    As you've viewed this thread since my last post, and are still online, can you clarify the above?
    Full Member spennny's Avatar
    Blantyre
    Seems he has off Duncan
    Yep, gone offline.
    andreitone - Given that you've viewed this thread since my other post, but not replied, I can only assume that you've had your question answered i.e.
    therefore I'll close the thread.
    If it's a copy, and I think it's fair to make that assumption given the circumstances, then can I point you in the direction of our rules and our stance on threads involving discussion of such (copied) software.
    If I'm completely wrong and you have a genuine copy then PM me and the thread can be reopened to help you with your problem - obviously we'd need to be satisfied that it is indeed a genuine version.
    Now confirmed via PM that it is, as was suspected, the Chinese copied version and exactly the reason why it wasn't working properly - therefore thread remains closed.
    Don't buy this stuff folks - it simply isn't worth it.
  1. Tech2 South West Area - Rain/Auolights Activation
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2011, 19:52
  2. Need Help with my Rain Sensor
    By nagnag in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2011, 20:07
opcom rain sensor
opel vectra c rain sensor
insignia rain sensor
op com rain sensor
