Thread: signum oil change.
    Regular Member eaglepva's Avatar
    Up North
    Default signum oil change.
    my signum is due a oil change, i fancy doing this myself and buying some good oil for the old girl. I have looked under my car but its got a cover under the engine.
    there is a circle cut out of the cover under the car about the size of a can of coke, and their is a bolt in the gap is this the sump plug?
    Leicester
    What engine do you have?
    Regular Member Jezzy's Avatar
    S.E
    Probably a diesel, given the under-engine cover.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    its a bolt on cdti and and dti its a torx... its diameter is about the size of a 50 pence piece (only round) the filters can be a bit of a pig to do on 1.9 as the are under the engine whereas 2.0 and 2.2 are done from the top... you'll need a tool to take cover off top off filter housing again different on cdti and dti....
    Up North
    DTi mate
  1. Signum Cambelt change
    By over60 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2012, 01:07
  2. signum grill change
    By tony stoney in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2010, 22:28
  3. Help ! Signum seat change
    By Lump in forum Bodywork & Interior
    Last Post: 4th April 2009, 15:53
  4. signum finished and tempted to change once again....
    By TIMMAH in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 18:42
  5. Signum brake pad change
    By apl in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2006, 16:53
