Results 1 to 10 of 19
Thread: Shower Sealant Silicone - - WHICH ONE??
    Birmingham
    Default Shower Sealant Silicone - - WHICH ONE??
    Need some assistance guy's.
    Have a shower cubicle and the edge where the tiles meet the shower tray started leaking, so we stripped the silicone sealant away and found it to be totally knackered.
    Anyway, have dried it all away and re-sealed with more moud resistant and waterproof shower & bath sealant silicone, but its started peeling away again, you can almost see that its started to come away from the shower tray.
    Any advice as to which is the bext one to use and which one wont start peeling away or coming away from both surfaces?
    Its blinking annoying!!
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Chester
    Is it peeling when someone gets in? if so it sounds like it could be because the plastic is deforming due to the weight. How about putting something heavy on the shower tray along with yourself whilst you fill it? (I'm thinking along the lines of filling a bath before sealing it)
    May 2007
    fleetwood
    hi, you should look for silicon that is "neutral cure" as this is far stickier than the ordinary "acetoxy cure" stuff, plus i agree with the above get rid of any deflection in the shower tray first
    andy
    Surrey
    Is the shower tray well fitted, does it flex when you stand in it?
    spoons
    Guest
    I used the new Unibond sealant - ready in 2 hours.
    Really good, easy to use. Ready in 2 hours
    Birmingham
    Thats a good point lads, as far as im aware its secure. I will try the unibond stuff, but where do I get this neutral cure from?
    Bye bye Vec B
    - Hello Siggy!
    Surrey
    Good DIY shops.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    dow corning all tha way mate, dear but good..
    Regular Member brickit10's Avatar
    haydock/st helens
    Quote Originally Posted by Vaux-Man-G View Post
    get low mod silicon most window fitters use it its the best to use should be able to get it from most hardware stores
    hull
    unibond the best for me pal.
    not cheap but you get what you pay for
  1. Silicone Sealant for Eyebrows
    By Envy in forum Styling
    Last Post: 30th July 2011, 14:45
  2. Bath or Shower?
    By Happy Girl in forum The 'Off Topic' room
    Last Post: 2nd July 2011, 23:56
  3. Advice about Silicone Sealant to use
    By James24 in forum Bodywork & Interior
    Last Post: 21st March 2009, 19:49
  4. Shower
    By moorlander in forum Comedy & Humour
    Last Post: 13th November 2008, 22:45
  5. anyone want a shower?
    By pogo in forum General items for sale
    Last Post: 11th November 2006, 10:41
unibond sealant neutral cure
