Results 1 to 10 of 19
Thread: searching but cant find
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default searching but cant find
    im looking for the post that explains how to fit a sub and amp to a standard cdr2005
    all i can rember is you connect a item to the rear speakers
    if anyone know the post im on about can you post a link as been lookign for over half an hour now and cant find it
    cheers Baz
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I've done it. You need a line driver or RCA converter. You put your rear speaker wires into the line driver, this is a small amp and then it sends the signal out via RCA's to your amp. The cheap fix is to use a speaker to RCA converter, only about £10 from ebay, this does the same thing but it isnt self powered and the sound quality isnt the best.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Linky for the cheap option.
    And LINKY for better option.
    Mar 2007
    swindon
    cheers rushy
    thats the kit i was looking for so you would recomend the line driver
    was it easy to fit? and did you do a how to
    cheers baz
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No how 2 mate. I just picked 2 items that I could find quickly on Ebay. I used the RCA converter. I traced the wires from the back of the HU and just cut into them. The rear speaker wires now split in 2, 1 part goes to the speaker and the other to the RCA converter. Most line driver's only accept RCA inputs, what you need is one that takes speaker inputs. You can just run 1 amp and 1 sub, but it would be far better to run an amp for a sub and another for the door speakers. HTH
    Regular Member hyperman's Avatar
    pontefract
    Line driver also known as a line level converter, fli (midbass) do these and they are pretty good, available at most halfrauds or a1 motorstores...they retail at £15 and are better than the cheap crappy ones off eBay..
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by hyperman View Post
    Do they have there own power supply?
    EDIT: Just looks at the FLI. Yes they are better than the cheap ebay stuff, it still doesn't have its own power supply, so from my understanding it isn't a line Driver/pre amp. The line drivers give a far better quality and stronger signal to your amps.
    Mar 2007
    swindon
    just looking at the bay and looking to get
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=360113852468
    Rushy would the above work with the fli line level converter or would i be better off getting the £60 piece of kit you put a link to above?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    halfords mate 6.99 am in the prosess of doin mine get the live from rear fues box remote of bak cig lighter and eart o ground of bak lights an rca 2 the front on the converter job done
    Mar 2007
    swindon
    make it sound easy mate
    any chance of posting some pics as your doing it
    think i might go down the cheap version first
  1. searching for members
    By gibbon7000 in forum General Chat
    Last Post: 26th November 2011, 13:58
  2. Searching the forum?
    By JSYSH466Y in forum General Chat
    Last Post: 20th February 2009, 22:10
  3. Searching For a Signum
    By DesignforLife in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2007, 07:25
