Results 1 to 10 of 19
Thread: the prize for the most frustrating warning light goes to...
    Sutton Coldfield
    Default the prize for the most frustrating warning light goes to...
    the bulb warning light.
    i can't see where a light is out at all, but i've got the damn light on the dash! argh! could at least show a little car icon with an arrow or something?!?
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Bets its a brake light, the canbus system compensates and puts another bulb on so you still have one either side.
    11 Post(s)
    Or a bulb is imminently about to fail. Resistance changes just enough to put the fault light on, but remains lit just that bit longer before going pop.
    If your car had the check control system then it would tell you which bulb it was.
    Had mine come on today with a picture telling me the offside brakelight had failed. Sure enough it had, and the lower side light bulb took over the role of tail/brake light. Took both light assemblies out, nicked the non working fog light bulb and used that for now until I get a replacement.
    Full Member spennny's Avatar
    Blantyre
    Bet its one of the bulb tracks in the back, that done my head in for months,
    Mine's good - it actually tells me which bulb is out on the CID... Even if it's the darn front fog lights which I don't use...
    11 Post(s)
    Quote Originally Posted by Penfold101 View Post
    They shouldn't blow if you don't use them
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    I think the Spanner light beats the bulb warning at least you know its not that much to fix and you only need to spend alittle time finding it.
    If its the spanner it could cost you a bomb and not know were the fault is
    Don't ask me how - they just did from when I bought the car to start with... Every single time i started it it insisted on telling you that both were out, indivually.... Ended up replacing them jsut to get rid of the warning...
    Regular Member SignumPhil's Avatar
    Luton, Beds
    My Siggy kept whingeing about one of the sidelight bulbs that was working perfectly. It would often come on or off when you went over a bump.
    Replacing the bulb fixed it, and when I took the old one out I gave it the old "flick" test and the filament broke, so I guess an intermittent, slow failure will still cause a warning.
    Phil
    West
    It could be a failing numberplate light... often overlooked when checking for a bulb out.
    hth
  1. Frustrating!!
    By RobW in forum General Chat
    Last Post: 6th February 2010, 18:38
  2. Replace coils or shock absorbers ?frustrating
    By babisskg in forum Handling & Braking
    Last Post: 13th September 2009, 12:48
  3. How annoying, confusing, frustrating and odd ?!?!?
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2009, 23:45
  4. Very frustrating??????!!!!!!!!!!!!
    By j6onn in forum Engine & Drivetrain
    Last Post: 4th June 2009, 22:35
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
