Thread: Any airbag gurus out there? help!
    Regular Member sri andy's Avatar
    Apr 2009
    Lancs/Manchester
    Default Any airbag gurus out there? help!
    Hi all, i have got to the stage of repair with my car where i want to turn the air bag light off after being repaired.I have replaced the passenger front seatbelt catch (the bit in between the seat and centre console) as it had deployed.This was the only part of the SRS system i could see that had deployed.I managed to get my mits on a second hand one and fitted it but cant get the airbag light turned off
    The local snap on dealer came today with some new shiney solus kit and i asked if he would try and all he got was something along the lines off ....
    No communication with steering coloumn module.
    Canbus cannot communicate and something to do with squibs?
    Should i have replaced the airbag ECU? will that be dead now even though just the seatbelt rocket deployed? Any help greatley appreciated
    Admin plasma's Avatar
    On the Forum
    217 Post(s)
    Engine : 150
    Mileage : 74000
    Right from what i know/did on mine was to replace all deployed airbags, what you've replaced is know as a selt belt pre-tensioner. When the airbag/tensioner goes pop if writes a crash log to the airbag ECU (situated underneath the handbrake almost), tech2 can sometimes clear the deployment record and then reset the fault codes, dont know what the circumstances of what it can and cant clear but it couldnt on mine. I sent my airbag ECU off to be reset by a specialist, it came back a few days later refitted cleared the outstanding codes and the light went off fine
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Apr 2009
    Lancs/Manchester
    So you had the ECU repaired and when you plugged it back in did the light go out straight away or did you then have to go and get the light extinguished?
    On the Forum
    217 Post(s)
    Engine : 150
    Mileage : 74000
    It didnt go out right away, i had to clear the codes (tech2) what they did was to clear the deployment record which allowed me to clear the codes.
    Apr 2009
    Lancs/Manchester
    Ah i see and how much if you dont mind me asking was the ECU repair?
    And also is tech 2 a vauxhall main dealer only thing and my only option? because the kit my local snap on man has seems to do most things, just dont fancy paying the dealer when i can get the light extingushed for nothing (if i can).
    On the Forum
    217 Post(s)
    Engine : 150
    Mileage : 74000
    Lemme see if i can find the people i used, was £60 i think, and any diagnostic tool which can access the airbag will be able to clear codes.
    www.crash-data.co.uk
    Apr 2009
    Lancs/Manchester
    Cool, thanks, been very helpfull mate
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Quote Originally Posted by sri andy View Post
    The local snap on dealer came today with some new shiney solus kit ...
    It could be just that
    I shouldn't tell you as I've a new airbag module I'd rather sell you
    Check all the plugs that plug into the airbags
    My light wouldn't go out but turned out to be the n/s seat plug wasnt seated fully
  1. One for you ice gurus
    By ftm100 in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 00:27
  2. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  3. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  4. Only for the Gurus
    By lizard in forum Photoshop section
    Last Post: 23rd September 2010, 15:15
  5. mot gurus
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2009, 20:45
vectra c clear deployment record
