Thread: heater inlet/evaporator location for Expanding AC Cleaner
    Regular Member Craig1985's Avatar
    harwich essex
    confused heater inlet/evaporator location for Expanding AC Cleaner
    Hi i have brought this expanding foam AC cleaner, http://cgi.ebay.co.uk/ws/eBayISAPI.d...fvi%3D1&_rdc=1 Where abouts is the heater inlet or evaporator outlet as described, as it says for best results spray from there?
    Regular Member SRimonkey's Avatar
    wednesfield
    under front pass seat i think???
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The RE-CIRC inlet is under the glovebox. Normal heater inlet is under skuttle panel.
    Detol spray works too
    harwich essex
    tried dettol but didnt work for me? i have mushrooms growing i think lol where would you squirt it, glove box inlet or scutle panel?i get the smell as i switch AC off? so would it be best if i use the cleaner with AC off?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    NO, put the car on AC and recirc and face vents with them all open.
    Squirt the stuff around the footwell area on passenger side. Shut door and leave on for a few minutes on full blower.
    Is that what you did with detol?
    Full Member
    Mar 2007
    Finland
    I've used similar foam-type cleaner, it is better to use with the hose supplied. Put the hose under the scuttle panel, to the blower motor (remove the pollen filter first http://www.vectra-c.com/forum/showthread.php?t=15090) and empty the canister.
    harwich essex
    its a foam tho not the usual spray stuff? i think will have a look for recirc enterance in footwell.
    Full Member
    Mar 2007
    Finland
    I've used this foam-type cleaner:
    These foamcleaners should be put via the air inlet channel into the evaporator, not via footwell, pls see this user instruction: http://www.crcind.com/wwwcrc/tds/TCA3%20AIRCOCLEAN.PDF
    (The usual spray-type cleaners are used in the footwell with recirc...)
    Wales
    With the foam ones, if the idea is to celan the evap/condenser, I have always thought that putting the hose into the drain would be a good idea. Anyone tried?
    The 'spray inside the car jobbies' have done nothing for me other than lighten my wallet!
  1. carb cleaner through the inlet???
    By craig-s in forum Engine & Drivetrain
    Last Post: 7th March 2012, 21:30
  2. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  3. inlet manifold cleaner
    By kev77 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 22:57
  4. Heater blower resistor location ?
    By poves in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 20:05
  5. Evaporator drain tube
    By jaxouk in forum General Chat
    Last Post: 19th July 2008, 11:43
