Results 1 to 10 of 23
Thread: Hello - I love my car!
    Devon
    Default Hello - I love my car!
    Hi,
    I've been a member of this excellent forum for a few months now, so I thought it was about time I introduced myself (I'm Darran) and share with you the love I obviously must have for my 2003 Saturn Blue Vectra GSI.
    I have owned it since 27 February 2009 and think it's an ace car, but below I've listed a breakdown of jobs I've had to do since owning, and the jobs left to do. I have to give a massive thanks to this forum for providing the know how and information that has enabled me to do most of the jobs myself - it has saved me an absolute fortune!
    By the way the car does have a genuine full service history (mostly at Vauxhall) and had done a genuine 60k miles when I purchased it. In my view that says it all when it comes to how thorough some garages are when performing servicing!!!
    In between all these jobs, I've also spent more time and money detailing the car (snow foaming, claying, polishing and waxing)!!
    And the question you're all asking - "Do I regret buying it"? - "No; not one ounce"!
    Jobs I've done to date
    No griffin badge on rear - fitted new one (not strictly necessary I know)
    Leaking fuel when car had full tank of petrol - fitted new Fuel Pump Cover Seal
    Very dirty / smelly coolant - drained, thoroughly flushed and refilled with fresh coolant
    Auto Transmission - drained and refilled with fresh fluid
    Missing Air Intake Pipe - fitted new one
    Flushed engine and changed oil 4 times over 1.5k miles (oil was very black). Now running with Mobil Synt S 5W40
    Replaced oil, air, fuel and pollen filters
    Slightly irratic idle - removed & cleaned the Throttle Body - it was very dirty but cleaning made no difference...so I then changed the Spark Plugs..... and then cleaned the MAF......still no difference!
    O/S/R Shock Absorber leaked all fluid - changed both rear shock absorbers for Bilstein B4s
    Excessively worn front and rear brake discs - replaced all discs and pads
    Unsecure exhaust heat shield - re-fixed using large washers
    Excessive play in both rear upper ball joints - changed N/S/R Upper control arm (have the other one to do)
    4 door locking button on drivers side not working - replaced switch panel (£10 from ebay)
    Jobs done by garage to date
    NCDC2013 Head Unit locked in 'Radio Safe' mode - Tech 2'd to re-pair with CID
    Spare Key Tech 2 Programming
    Missing O/S/F Tyre Pressure Monitor - fitted new one and Tech 2 programming
    Worn front tyres - 2 new tyres fitted
    Built in CD changer stopped reading discs - repaired by audio specialist
    Jobs to do by Garage
    Replace cambelt and tensioners (car has done 62K miles and is 6 years old in October) and diagnose slight oil leak coming possibly from behind cambelt at same time
    Both rear tyres worn - fit 2 new tyres (once rear suspension repairs made)
    Slight play in O/S/F Tie rod - replace tie rod
    Have a 4 wheel, wheel alignment done (when all suspension mods / repairs done)
    Jobs for me to do
    Excessive play in upper O/S/R balljoint - change O/S/R Upper Control Arm
    Change both rear ARB bushes
    Dual Climate Control Panel - the button to activate air con and air distribution is knackered - fit new one (£245 & needs Tech 2 programming - aaghh!!)
    Change brake fluid
    Exhaust tailpipes starting to blow - change both exhaust tailpipes for Remus (half the price of gennuine Vauxhall ones!!)
    Fuel evaporation hose going into the throttle body is perished - fit new one (costs approx £75 for hose - ouch!!)
    Change both front ARB Bushes and front drop links
    Fit Eibach Pro Springs all round
    Fit Bilstein B4 front shocks
    Regular Member AdeyCorp's Avatar
    Chesterfield
    Welcome to the site/club, it is a very nice place to come to & enjoy & help.
    But we need to see photos, it is the rules !!!!!!!
    Cambridgeshire
    Enjoy the site
    Full Member gibbon7000's Avatar
    lincs
    to the site. Sounds like you've been a busy boy. Keep up the good work. btw, whers the pics, its the law around here.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Welcome to Vectra-C.com don't forget a pic of your motor ……….…
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    welcome to vec-c, we do need to see your motor
    WGAF#5
    hello and welcome
    i noticed your doing tyour rear arb bushes
    save yourself dome money and do your osf tie rod end as well
    easy as pie
    good luck atb
    Dez
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Debadge it
    Pics, pics pics pics.....
    Regular Member skip's Avatar
    wakefield
    Regular Member zazaszazas's Avatar
    Cumbria
    hello and welcome
  1. Do You Love Your VX ?
    By HITFACTORY1403 in forum The 'Off Topic' room
    Last Post: 10th July 2011, 13:49
  2. got these love em!!
    By mitch in forum Styling
    Last Post: 22nd October 2010, 21:24
  3. Got one and love it.
    By whitey2 in forum Introduce yourself.
    Last Post: 2nd May 2010, 13:26
  4. why i love my job sometimes
    By PeteRs in forum General Chat
    Last Post: 7th March 2008, 09:03
  5. love this first pic.
    By kev bux in forum Quick Photo Album
    Last Post: 29th January 2008, 18:27
