Thread: Turbo again?
    South London
    Default Turbo again?
    Hi
    About a year ago I had a new turbo fitted. The old one broke up and caused an almost total loss of oil.
    My car is a 2.2DTi, 04 registration.
    Last night I noticed that every time the revs. get to 2000 a high velocity noise similar to a high wind comes from under the bonnet. It is quite loud and can be heard with the windows open or shut. Performance doesn't seem to be affected.
    What do you think, could it be the turbo again?
    [Ex]Admin Duncan's Avatar
    Could be a split turbo hose? Are you getting any spanner light when accelerating under load?
    South London
    Hi Duncan
    Thanks for replying.
    I have checked the hoses for splits and loose connections and all looks o/k.
    Also no warning lights.
    Any other suggestions that may help will be welcome.
    Full Member gibbon7000's Avatar
    lincs
    I would go with what duncan has said, strange that theres no loss of power tho
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by gibbon7000 View Post
    same here, i would put my money on a split boost pipe, ......can you get someone to rev her up while you investigate???
    South London
    Hi
    Have found the problem.
    You were all spot on with your diagnosice. The bottom turbo hose had a small split in it.
    Couldn't see it until I removed the hose. All working fine now. Thanks for your replies.
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. Turbo Help
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th February 2010, 11:42
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
