Results 1 to 10 of 17
Thread: signum boot? cant work it out
    north west
    Default signum boot? cant work it out
    When i press the remote to unlock the doors etc... the boot light comes on but the boot half opens (kind of disengages but wont open) so to get the light off i push on the tailgate to lock-the light then goes off.
    All the lights work fine but when i go through the system again straight away---lock with remote then unlock,there is nothing at all from the boot......this really is getting so annoying now,any ideas?or soloutions
    WGAF#5
    the boot release button on the door and keyfob are there to "release" the boot to be opened manually by hand - the boot remains locked at all other times the lights com on the no plate lamps to show you that you have access
    the button will allow the boot to be opened for 10 minutes iirc so the boot should not partially open when you press the button it should remain in the closed position and only open when you press the microswitch
    i suspect if it is partially opening that the micrswitch has failed and is releasing the boot - you may wish to look at this as the fisrt port of call
    hope this helps
    north west
    Thanks for posting when you say it has failed is this a repairable part if so how is it done
    WGAF#5
    Quote Originally Posted by stec View Post
    it will be worth stripping the rear boot trim off and removing the microswitch (boot release switch) and giving it a good spray with contact cleaner and then retesting - if this works then all well and good - if not then i suspect its going to be a replacement switch
    how 2 here
    http://www.vectra-c.com/forum/showth...+switch&page=2
    regards
    Dez
    Given your description it's definitely the micro switch as per the link to my remedy that dez gave. If you do go to the extent of stripping out the switch then for the sake of £18 you may want to consider getting the modified version of the switch that they do - no longer has the captive ball bearing that gets gunged up.
    Mine started playing up again at the weekend at PVS but typically seemed to be okay when I got back! I've gone and ordered the switch anyway as I'll just replace it and be done with it.
    north west
    wow how good are you guys i got to the ball bearing and sprayed with plus gas and it is now working greeeeat but cant get rubber in now(thats a problem for later) lol
    also...............
    When i open my tailgate it have to keep it up by hand otherwise it just falls down??
    WGAF#5
    also...............
    tailgate struts will be next on the list then
    north west
    i dont know are they knacked or can they be repaired i am on a roll now lol
    Yep, that's the tricky part that involves the subsequent trim removal. - although one person said he had managed to twease it all back in again without having to remove the trim. Gawd know how though! lol
    As for your struts, sounds like they are losing their gas. Dead easy to replace - one bolt at each end, job done.
    north west
    do you have to get them in pairs or single as i dont know which one would be damaged,what kind of price are they lol
  1. Idea for boot lighting, should work?
    By Shogun in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2012, 10:29
  2. Signum Coilovers - Would these work?
    By DarrenLee in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2012, 23:36
  3. HELP PLEASE!!! Which Double Din in Signum so top screen will still work?
    By ne1cdamo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 23:05
  4. My New Signum! Let the work commence!
    By Maverick in forum Quick Photo Album
    Last Post: 22nd December 2008, 08:05
  5. Would this work in a Vectra/Signum?
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 17:28
