Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Engine management light
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    Default Engine management light
    Put a performance filter on last night. Drove 30 miles this morning and cruise wouldn't work so stopped turned engine off and waited a few minutes. Off I went again, still nothing but now my engine management light is on. Feels fine to drive, no lose of power, will happy climb to 80mph. Help!
    May 2006
    scotland
    There should no be anything in that area associated with the filter. Was it a panel filter or did you take the original box out and replace with a cone type filter. Make sure the MAF sensor connector is properly connected. Good Luck. It maybe that the filter is letting in 2 much air but never heard of this yet. Maybe complete coincidence an it was going to happen anyways.
    CORNWALL
    Replaced with panel filter. Will see what happens when I go home tonight. Car would of been sat for 12 hours then
    Regular Member AdeyCorp's Avatar
    Chesterfield
    Thats not good, u only got that saturday. Have u done the air box mod as well or not? But either of those mods should of caused that issue. But there could be a unrelated issue maybe, as a air filter change shouldnt of cause the cruise control to stop working.
    Not much help sorry.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Double check everything under the bonnet, maybe you caught a plug connection somewhere when taking the airbox lid off - could be something simple.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    disconnect the battery for 30 min, as it will reset the ECU
    Regular Member dan1983's Avatar
    North London
    i had same problem when i fitted a k&n filter to mine, took it to get checked and it came up as oxygen sensor, never got it changed though and now and again the light pops up, but its off at the moment
    CORNWALL
    How much is a tech 2 session normally? Not too worried about cruise, just the management light being on!
    Plymouth
    Quote Originally Posted by Matt&Jemz View Post
    £60-£85 pops to mind for some reason
    CORNWALL
    Will look at the how to diy style when I get home and try that first. Was still on after 3 hours of standing still. Matt's wondering if he put it back together the right way
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
