Results 1 to 3 of 3
Thread: 2.2DTI Spanner fault Light.... HELP
    Regular Member n30jjb's Avatar
    Barnsley
    Default 2.2DTI Spanner fault Light.... HELP
    I've ogot an 04 Signum 2.2 dti and have been experiencing the spanner fault light and the car goes into safety mode, no power etc. My garage have had it twice and have not been able to find the cause as the car shows no fault codes. ANY IDEAS?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Try cleaning the EGR and the boost sensor. Also clean your fuel lines with some reddex or millers
    Barnsley
    It ended up being a split pipe coming off the turbo causing a lack or pressure
  1. 2.2dti spanner light at idling?
    By bigben in forum Engine & Drivetrain
    Last Post: 27th January 2010, 21:05
  2. 2.2DTI LIMP MODE + SPANNER + Engine Managment Light
    By s0501291 in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:42
  3. 2.2dti only revs to 2600 rpm- spanner light on
    By nutty0069 in forum Engine & Drivetrain
    Last Post: 25th January 2009, 15:42
  4. 2002 Vectra C 2.2Dti Spanner Light Help
    By kktdragon in forum Engine & Drivetrain
    Last Post: 7th January 2009, 01:34
  5. Spanner light and slight loss of power 2.2dti
    By nickd_m in forum Engine & Drivetrain
    Last Post: 10th November 2008, 23:28
vectra c 2.2 dti spanner light
