Thread: Climate Control probs following car wash
    Jun 2009
    TF
    Default Climate Control probs following car wash
    Took my 2003 Vectra Elite 3.2 through a car wash the other day.
    Following the car wash the fan on the climate control started making a few noises and the speed varied on the fan, then it stopped working.
    Checked the fuses all seem ok.
    Read online that water has entered through the ducting. The problem could be the fan or a resister pack which is failed.
    Anyone experienced this problem??
    Jun 2009
    TF
    Oh yes, the climate has 7 speed setting not 4 like the normal air con.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Sounds like your scuttle panel/pollen filter water drain is blocked causing the water from the car wash to enter the cabin. There are loads of threads on here with similar symptoms. The water causes a resistor to short out and requires replacement.
    Heater motor and resistor
    Jun 2009
    TF
    I have just dismantled the internals of my vectra, only to find that there does not seem to be a resister pack where the 4speed aircon one is on the photos attached to the other thread.
    Help. Can anyone else explain the 7 speed climate resolution, or is it time for a big bill?
    I need to find my multi tester, to see if I am getting any power to the fan?, or whether it is part of the dash controller?
    cheers
    Did you check the drain in front of the pollen filter before you do anything else ....
    Jun 2009
    TF
    Sorry, all of this car maintenance is new to me...
    Where will I find this?
  1. climate control
    By stu_c in forum Bodywork & Interior
    Last Post: 5th January 2011, 12:34
  2. climate control
    By stu_c in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 18:27
  3. air con climate control
    By clembo38 in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2010, 12:42
  4. Climate control
    By Mogsy007 in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2010, 00:19
  5. Climate Control
    By mbonnick in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2006, 08:05
