Thread: front Indicator bulb
    Regular Member davieboy1976's Avatar
    hamilton scotland
    Default front Indicator bulb
    Quick question on the sri (06) How the hell do you get to the front indicator bulb passenger side, HELP cheers
    WGAF#5
    if its the headlight one - disconnect the washer bottle neck - move it to one side and remove the cover
    replace bulb -TEST ITS WORKING then refit washer bottle neck and cover
    stand back and admire your amazing handywork
    if its the drivers side - prepare to bleed all over your car attempting to replace a bulb
    11 Post(s)
    As said above. If offside, either front bumper partially off to remove headlight, or partially remove airbox to gain access.
    Either way, its a PITA (or hands if you do it via the airbox removal route) I still have the scars to prove it when I changed the headlight bulbs.
    North Bucks
    Default Sidelight bulb.
    The airbox out route is easier IMHO.
    Just make sure you don't try to start the car or even turn the ignition on with the MAF sensor plug removed or you'll give yourself an error code or worse.
    A little bit of vaseline makes it much easier to slide the airbox mounts back onto the body clips.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I did the indicators and side lights on mine last week, took about an hour all in. Loosened the front bumper and removed headlights.
    Regular Member Cossy's Avatar
    East Yorkshire
    I opted for find someone with very small hands to do it for me, it worked a treat without having to remove anything at all!
    Apr 2006
    Quote Originally Posted by Cossy View Post
    I just about managed it on my old prefacelift but still had to remove loads of bits.
    On the facelift, I even had to use pliers once I had the headlight out and disconnected. Blimmin sausage fingers!
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. Facelift Front Indicator Bulb
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2012, 12:28
  3. Front indicator bulb
    By Mopar Man in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2011, 22:17
  4. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  5. indicator bulb
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 18:57
