Thread: k&n panel filter care...
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default k&n panel filter care...
    was wondering if anybody has used the k&n cleaning spray and oil stuff, if so is it anygood? or what other ways of cleaning it are they?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by bobby-tupper View Post
    They can become too oily and contaminate MAF sensors and the like - if its done regularly then just a tap and a hoover should suffice. You would only need to oil it yearly to be honest, but just not too much (the oil helps with the filtration).
    Regular Member silverhairedracer's Avatar
    ESSEX
    Only last week cleaned and re-oiled my filter using the kit you can buy,follow what it says on the box and there should be no problem,just do not get carried away when you re-oil,I left my filter overnight so it soaked well in then any excess was wiped off using kitchen roll.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    how long does the filter take to dry when you have rinsed that spray cleaner stuff off?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Leave it for a good while, if possible put it somewhere that a draft can blow through it i.e a window. I left mine overnight
    West
    As said just follow the instructions on the recharge kit, remembering not to go mad when you re-oil.
    I usually take a couple of days to do mine, wash through & leave overnight to dry out before re-oiling, then leave overnight again for the oil to soak in.
    hth
    ESSEX
    hth
    I did mine the other sunday which we are now calling the "summer" nice and hot and sunny soon dried.
    Regular Member bushygrunt's Avatar
    Wakefield
    I did my K&N fiter on my St before i sld it, basically do what it says on the tin.
    Spray the cleaner on the dirty side of the panel leave for around 20 mins to aggitate most of the crud off, then turn it to the clean side ( the side that faces the inside of the air box, so as not to push the grime into the pleates ) then using normal pressure tap water ( NOT JET WASH ) rise all the crud off, leave around 24 hours to dry, then re-oil with the spray using very sparingly, then leave for 1-2 hours see if there are any white spots on the pleats if so do a spot spray.
    Leave for 24hours to settle, wipe excess off the rubber surround and:-
    Robert is your mothers brother......
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    cheers for the advise m8, how much milage isit untill it will need a clean/service
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by big rich View Post
    not sure mate im just going by the state of mine when i took the air box lift off lastnight
  1. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  2. K&N Panel filter
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 16:05
