Thread: TID to BID display ??
    Jun 2009
    Home
    Default TID to BID display ??
    Sorry for asking something that may have already been answered.
    I have just got a 2005 vectra with a CD30 radio with TID display. For me to get mpg etc on the screen i would need to fit a BID display as a minimum (or CID/GID).
    I've read in previous threads that if buying second hand i would need a BID that has been uncoded using a tech2 when removed and then coded once fitted to my car.?
    Is the display coded to a particular control unit on the car or just the CD30??
    I have seen the CD30 and BID for sale together and wondered if this would work without the coding.???
    I thought i was getting my head around this mod but once again i've confused myself !!
    Thanks in advance
    Dan
    Surrey
    Display and radio are paired, keep them together and they are happy.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Surrey
    I was going to say married but some would argue, keep them together and they might not be happy.
    Jun 2009
    Home
    Cool, Thanks for the help peeps. Took the plunge and aquired a CD70 and CID today.
    I held my breath and plugged in the new radio and display, first signs are that every thing seems to work minus the gps signal which i knew would need a receiver for.
    I also wanted to gain mpg etc as mentioned earlier, it appears that this function is still not available. I think this needs to be enabled via tech2 or similar.
    Can anyone confirm what has to be done as a testing call to my local dealer was fruitless to say the least! I'm guessing another control unit needs enabling as the radio needs to be sent the info first?
    Thanks in advance
    Dan
    Jun 2009
    Home
    Default TID to CID and CD70
    OK i have sorted it out now, a local auto electrics firm had a tech2 and with a bit of help we managed to sort it out.
    It would seem that you need to reprogram a module with new index codes to confirm that the car has board computer installed.
    I can't remember if it was the DIS or CID module ! oops ! Although when the guy went into code index programming on the correct module he knew what to do by folllowing the on screen info.
    I hope this may help someone else at some point and i apologise if it has already been said.
    Now all i need to do is install the gps receiver. I wish i had taken the time to remove the antenna loom from the donor car as i did get the original gps antenna. Am i right in thinking that a gps receiver with the fakra connection can be brought from ebay ??
    Over & Out
    Dan
    Surrey
    Yes you can buy them cheap enough on Ebay. Can you still get to the donor car?
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. mp3 on display
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2011, 14:54
  3. PS3 display
    By @ndy-e in forum Games Room
    Last Post: 27th December 2010, 08:21
  4. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  5. LED DIsplay
    By dcraigen in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 10:16
