Thread: got my first problem.. well
    Jun 2009
    birmingham
    Default got my first problem.. well
    i've been driving the car, and have heard a slight knocking from the rear passinger side wheel, it has been getting worse over the last week, so this evening i jacked up the car to check the wheel bearing, and found that the wheel/hub moved up and down, but not side to side? the bushes seem to be fine with no movement, is it the bearing? as there is no grumbling sound? thanks
    Sunny Dartmoor
    shocks maybe.......
    Jun 2009
    COUNTY DURHAM
    My vectra did exactly the same, l changed the top control arm, only cost 35 quid and it solved the problem straight away.
    Best of luck...
    Jun 2009
    birmingham
    i jacked it up today and found BOTH the rear springs had broke??? so replaced them (£45 the pair) they are more heavy duty too
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
