Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: More Comp Guru Help Needed
    Full Member spennny's Avatar
    Blantyre
    Default More Comp Guru Help Needed
    Can you let me know why i am getting this screen, i think its because the last time i formatted, its something to do with Partitioning ?
    Can i remove it so it goes straight to the windows password screen ??
    Regular Member SRimonkey's Avatar
    wednesfield
    looks like you got 2 copies of windows xp running,looks like ya didn`t format it,you installed it again
    [Ex]Admin Duncan's Avatar
    Have you recently reinstalled XP and did you tell it to do it on a new partition?
    If so then you can just remove that other partition to get back to a single OS boot.
    Blantyre
    Was all new to me , formatted a while ago, i dont think i did install a partition, i always click the top one, how do i avoid this screen, or do i have to formatt again ??
    Newcastle under Lyme
    yes delete the partition when youve loaded the correct version of windows by formatting like you would a floppy drive then edit the win.ini file to remove the second install they are listed in the same order ie if you loaded into the 1st instance delete the 2nd line
    If there is no other partition it could just be the win.ini file still points to a non existant copy
    Blantyre
    Sorry guys.... any english translations, easiest way, dont want to format
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Try the second one and see if it boots up. If it does you have two copies of the o/s installed.
    If not, you could edit boot.ini to lose the second one.
    If you don't feel confident doing this, then don't as you could render your system unbootable.
    Phil
    Blantyre
    How do i find these files
    have you tried loading the 2nd version?
    to change teh win.ini
    Right click my computer
    Click Properties
    Click Advanced tab
    Under startup and recovery click settings
    (Theres a little dropdown box which will have the 2 titles win xp etc.)
    Click Edit (this is win.ini) and delete the 2nd title one this will take it away at startup and appear normal
  1. Notebook Help Please - Computer Guru Needed
    By spennny in forum The 'Off Topic' room
    Last Post: 22nd July 2010, 16:25
  2. Guru
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 9th August 2009, 18:04
  3. Help from the e bay Guru,s Needed.
    By ed taylor in forum The 'Off Topic' room
    Last Post: 18th July 2009, 21:31
  4. I'm a GURU!!
    By Big Sig in forum The 'Off Topic' room
    Last Post: 5th December 2008, 11:19
  5. Guru`s ???
    By Bainie in forum General Chat
    Last Post: 17th November 2007, 11:55
