Results 1 to 10 of 14
Thread: Creaking clutch pedal
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Default Creaking clutch pedal
    My clutch pedal is creaking and it's getting on my t1t5 !
    Seems to be coming from the very top of the arm.
    Tried various lubricants but still creaks !!!
    Anyone else got this problem ?
    Glasgow
    Mine also does this, pain in the rear end.
    Regular Member Robbie69's Avatar
    Mine does it too, not found a cure yet.
    Dodgy spring maybe...?
    Jan 2006
    Dalriada
    My 2.0T does the exact same and it annoys the hell out me
    WGAF#5
    white grease worked on mine
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    To be honest I've not noticed it on my Vec-C, however you've reminded me that EVERY Vauxhall I've driven from late 80's models onwards (owned 7 in total) all had the same squeek!! Think I cured most by turning the radio up
    You watch, I'll get in mine tonight and hear it lol
    Regular Member 98vectra's Avatar
    stoke on trent
    Where do you apply the grease (yes i know on the clutch pedal but what part of the clutch pedal ?)
    Regular Member Swaite53's Avatar
    South Wales
    I've not got it on my Vec C, but have had it on previous Vauxhalls. It always seemed to be there when I had the heater blowing hot, or on very hot days, and would go away when the temperature cooled down.
    It was the spring at the top of the clutch pedal arm. I think the heats dries it out. I applied numerous lubricant and it only cured it for a short while. I eventually came around to using Lithium Grease, and it went and stayed away for good after that.
    It's very difficult to see, as it's usually behind the dash. You can get your arm up there quite easily though. I'd recommend a mirror and a torch to guide you.
    I've just realised how dirty it is in my footwell; I don't usually see it from this angle. I'll have to get onto that on the weekend.
    Regular Member barkzz's Avatar
    Its normally the spring as others have metioned, i just got some WD40 and gave it a damn good spray. Then put the floor heaters on full blast, and gave it another spray. Problem Solved.
    Quite common on Ford's as well
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Creaking clutch pedal
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2012, 12:12
  3. Creaking clutch pedal
    By Marky in forum Troubleshooting
    Last Post: 20th June 2011, 08:40
  4. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
  5. creaking clutch pedal
    By north in forum Engine & Drivetrain
    Last Post: 13th October 2007, 14:42
