Results 1 to 10 of 14
Thread: AC recharge cannisters
    Regular Member Readster's Avatar
    Plymouth
    Default AC recharge cannisters
    I popped into Halfords today (as you do) and spotted Air Con recharge cannisters for about £12.
    Attach to the big pipe inlet and 20 minutes later job done, its even got a gauge to tell how much re-fridgerent is in your system.
    Ummm...
    I had always though that a 'recharge' meant removing all (or as much as poss) the gas/ lub oil and then refilling it with the correct amount of lub oil & gas so the system works correctly. That is why is as much £p as most AC people charge.
    An overfill being as bad as an under fill.
    Has anyone tried the Halford's solution?
    Full Member spennny's Avatar
    Blantyre
    Would be interesting to know
    Mine is crap !!
    Surrey
    I wouldn't bother, do it properly.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My mate tried a DIY kit on his car and it worked fine.... easy to do too.
    WGAF#5
    every vehicle has an amount of gas /refrigerant shown on a sticker on the front chassis plate of the vehicle if you under fill - it wont work
    if you over fill it wont work - i suspect these "cannisters" operate on a pressure equalisation similar to top up charging of batteries etc...
    if there as cheap as you say they are nothing to loose and everything to gain - do the cannisters come in different sizes?
    do they have a website you can check first ??
    good luck and remember to stand back when you start your car
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    I fully regassed my Cavalier a few years ago using a kit of cannisters I got online - oil charge, dye and refrigerant.
    It worked OK - maybe not as icy as it could have been, but still cold.
    I found that it was best to get enough gas in to get the system running, then go for a drive, come back and top up whilst the engine was still running. Only problem there is the fill valve was right next to the downpipe !
    Now, with Kwick Fit charging £45, it's as cheap to go there
    Full Member Big Sig's Avatar
    IMO these are a quick soloution if you are going to sell it. Overcharging is worse than under charging as the compressor could pull liquid back and slowly destroy it as its designed to compress a gas to a liquid not a liquid to a liquid.
    Regular Member adfrodsham's Avatar
    lincoln
    Quote Originally Posted by spennny View Post
    Mine is crap !!
    our first volunteer me thinks, lol
    Blantyre
    Quote Originally Posted by adfrodsham View Post
    LOL... no chance, I'll wait for the monkey
    lincoln
    for the price might be worth ago, might save you 10-20 quid, but you might loose a tenner, good odds though
  1. Air Con Recharge
    By garetmcc79 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 16:41
  2. K&N Recharge
    By spennny in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 15:05
  3. Air-con recharge £25.
    By frasedeb in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2010, 20:58
  4. Air-con recharge
    By frasedeb in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2010, 10:17
  5. Air Con Recharge £25
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2009, 19:36
vectra c ac top up
