Thread: Brake and clutch fluid change questions.
    Nottinghamshire
    confused Brake and clutch fluid change questions.
    I need to do a brake fluid change as it's 2 years since the last one. Can anyone tell me how many litres of DOT4 brake fluid I need? I don't want to run out part-way through, but it would be nice not to have loads left. I will be using the trusty old Gunson Eezibleed to do the fluid change.
    Also, should I bleed the clutch at the same time to change the brake fluid that it uses? It's difficult to do on my 2.2 DTi because the bleed valve is hidden under a big bunch of cables that you can't move out of the way. I don't think that Vauxhall or Haynes mention a need to change it regularly, but I'd like to change it if it's best to do so.
    All advice and opinions welcome. Thanks.
    [Ex]Admin Duncan's Avatar
    Using the same kit I used 2 and a bit of the 250ml bottles to fit new calipers and give it a good flush through to change the fluid. Could've probably got away with just the two but I was making sure.
    Nottinghamshire
    Thanks, Duncan.
    Sounds like I should be safe with one 1 litre bottle for a full flush then.
    Any thoughts on bleeding the clutch as well?
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    Quote Originally Posted by James24 View Post
    Thanks, Duncan.
    unless you have issues with the clutch i wouldnt worry about it mate
    Rubbin'z racing Harry!
    Oh yeah, more than enough.
    As above, no need to bleed it unless you're having specific issues.
    Nottinghamshire
    No problems with the clutch at all. Just wondered if it was best to bleed it along with the brakes so that the old brake fluid in it didn't mix in with the fresh brake fluid in the rest of the system.
  1. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  2. Brake fluid change
    By rob warrington in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2012, 15:52
  3. Gearbox/clutch/brake fluid change-TOMORROW!!
    By nikroc in forum Engine & Drivetrain
    Last Post: 23rd February 2010, 22:49
  4. clutch fluid change
    Last Post: 16th November 2009, 23:44
  5. Brake fluid change
    By estra7 in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2008, 12:26
where to put clutch fluid in vauxhall vectra
https:www.vectra-c.comforumshowthread.php84197-Brake-and-clutch-fluid-change-questions
how to change clutch fluid in vauxhall zafira
vectra c clutch fluid replacement guide
vectra clutch fluid
is the clutch fluid in same place as brake fluid.on vectra c
vauxhall vectra brake and ckutch fluid
vectra special v6 clutch fluid
zafira clutch fluid replacement
brake fluid vauxhall vectra
2007 vauxhall vectra clutch fluid replacement
how much fluid goes into the vectra c brake system
2005 vectra cdti brake clutch fluid
