Results 1 to 10 of 15
Thread: Steering wheel + ESP lights up.
    Apr 2009
    ROMANIA
    Default Steering wheel + ESP lights up.
    I'm wondering if someone here has faced (and solved) this problem...
    Last winter, at cold temperatures, while driving on a bad road surface, ESP lighted up my dashboard. Trying to park the car, when steering wheel reached neutral position, a light on dash of steering wheel with exclamation mark appeared and turning signal didn't turn off.
    I have turned off and again on the engine, all seemed to be normal.
    After some days, when reversing, Damn ESP lights up. Steering wheel comes to neutral position, again light on dash of steering wheel with exclamation mark.
    This problem reccured 90% when reversing, about 10-20 times after.
    I have changed my battery (it was from 2003), corrected the wheel alignment, put it on tester (there was an error about Steering Angle Sensor - not present).
    Meantime, outside temperatures have increased, and the problem didn't reccured. At OPEL Workshop they told me it must be the CIM causing this problem. Should i go for a new one, or there's more tests to do?
    Regular Member zazaszazas's Avatar
    Cumbria
    i've had similar problem....I've had a faulty steering wheel angle sensor,i've changed that and no problem since then...
    Apr 2009
    ROMANIA
    10x for a quick reply.
    did u faced same problems as i did?
    Cause for the CIM, i know there's several more ... like steering wheel commands not working, dashboard turns off for few seconds etc, and i didn't have any of these.
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Quote Originally Posted by zazaszazas View Post
    I have a fault with the steering angle sensor, could you explain what is invloved in changing it, location etc and how much was the new sensor?
    Jun 2009
    CZ
    Hi rookie, I have experienced exactly the same behaviour on my Signum tonight.
    Would you please tell me how did you resolve the problem? Thanks.
    Full Member
    Bristol
    I would get the steering angle sensor calibrated first. I had the esp light on calibrated it an now it ok.
    Almost the same as what I had some time ago
    Traction Control and Steering Wheel warning, and indicators fail to operate correctly or cancel
    Traced to the CIM module and replaced under warranty
    Oct 2009
    Kent
    I have got the exact same problem now, happens exactly like you say so whats the verdict to get it solved? expensive as its not under warranty i have an 03 3.2 V6 Vectra??
    You are looking at £200 to £250
    It doesn't take long though, if the parts are in stock you are looking at about 2 hours
    Full Member Big Sig's Avatar
    Quote Originally Posted by MNC View Post
    Get the codes read as it could be either the cim or more likely steering angle sensor. Mine did it a few times, but only when reversing slowly on full lock.
  1. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  2. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  3. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  4. Replies: 6
    Last Post: 13th March 2011, 10:47
vectra c cim module esp light
esp light vectra c cim module
