Results 1 to 10 of 13
Thread: CDTi 150 Missfire
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Default CDTi 150 Missfire
    Wondering if anyone has any ideas. My 54 plate CDTi 150 has develpoed an extremely annoying intermitant missfire. On light throttle and cruising i get a miss every so often. I've checked all the connections at injectors sensors etc. It's showing a P0002 fault, Fuel Volume Regulator Control Circuit Range/Performance, which logs every now and again. It can be months between faults but lately it happening far more regularly. Anyone had this? Any ideas? I'm pulling my hair out.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I'm having a similar problem on my 3.0CDTi. It's caused by a gunked up turbo apparently...
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    got the same problem on one of my cdti's. Under light/partial load a slight judder/misfire for a cpl of seconds, but under full load is fine.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Is this not usually the symptoms of the 3rd injector - thats what mine was doing before I changed the plug to new type.
    Nov 2007
    Ayrshire
    Would this bring up a stored fuel pressure fault though?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by sdemps View Post
    Pass, never had my codes read.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by plasma View Post
    That's what my 3.0 is doing...
    Nov 2007
    Ayrshire
    Well spent some time at it today, the sensor that is reading the fault is the one connected to the rear of the high pressure fuel pump. Anyone had faults with that? I did some digging but couldn't find any info and my local stealers haven't had any fail!! Could it be something simple like dirty fuel? Any ideas?
    Malton
    I've had this problem for a while, then on Thursday car went onto running on 3 pots
    Got AA out, he messed about with connectors and it seemed to clear.
    Came home last night and it was ok while under power, but coasting upto a roundabout or top of slip road with no throttle on (in gear), once I tried to accelerate it was very rough
    Eventually this roughness wouldn't clear and a nice man in his truck came and took us home.
    I'd like to know what people think, a could of guys I've talked to think it's a fuelling issue. All the AA man saw that was odd was a high fuel pressure reading he said, that didn't drop as expected when the ignition was turned off. Sounds similar? He got no fault codes from his reader, but said his generic one couldn't read them all. He was surprised I got to engine management light though too....
    G
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Mine is still chugging along occasionally, no DTC's at all for it. Already had 3rd injector rewire, but gonna do the other 3 to be on the safe side. Ordered the pack of 4 so will have one spare one if someone wants it.
    Quote Originally Posted by Northy View Post
    G
    Defo sounds the 3rd injector plug has packed up for good. Price should be approx £25 for parts and possibly £90 for 1hr's labour at dealers to sort.
  1. Serious missfire 3.0 V6 CDTI
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 14th August 2011, 07:45
  2. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. missfire
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 28th October 2009, 00:43
  4. 150 cdti 1000 rpm missfire
    By sshooie in forum Diesel Engine related
    Last Post: 4th July 2009, 11:08
  5. 1.9 cdti missfire
    By tobybongo in forum Engine & Drivetrain
    Last Post: 17th November 2008, 01:04
