Thread: Weird Air Conditioning problem?
    Jun 2009
    London
    Default Weird Air Conditioning problem?
    I have a 2001 (X plate) Vectra.
    I'm getting an intermittent problem, maybe once a week the engine light comes on (the engine shaped one, not the spanner).
    I have a 'memoscan' code reader that has got me out of trouble before and it will reset the light, but it does not show a proper fault code, just N/A.
    I have now discovered that when the light comes on, the Air Con stops working. However, if I reset the light (even without turning off the engine) the A/C starts working again.
    Does this make any sense to anyone? What could be the problem?
    WGAF#5
    probably a problem with the 2 speed fan relay - when its faulting its preventing the ac operation and bringing on the lamp
    hth
    regards
    Regular Member gotlosi's Avatar
    hampshire/uk
    i would go the relay route before spending money.
    Jun 2009
    London
    Thanks for the rapid response guys...
    Could you tell me where this relay is located please?
    hampshire/uk
    i think it is one of the ones in the engine bay as i wouldnt have thought theyd put it inside the car. unsure of the one though as away from home pc and car so hopefully someone else can help out there.check the engine ac (air con) fuse is not corroded and pushed in correctly aswell.
  1. Weird Problem with PC..
    By macdad in forum General Chat
    Last Post: 28th March 2012, 23:36
  2. Weird problem
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2011, 19:12
  3. Air conditioning problem
    By antchev in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2010, 10:44
  4. weird possible ABS problem?
    By Xerath in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2010, 15:46
  5. Air conditioning problem!!!!!!!
    By Fedex in forum Bodywork & Interior
    Last Post: 16th February 2009, 17:18
opel vectra ac problem
