View Poll Results: cleaner used for cleaning the egr
Voters
30. You may not vote on this poll
  • carb cleaner
    22 73.33%
  • engine degreaser
    0 0%
  • white spirits and others
    7 23.33%
  • elbow grease
    1 3.33%
Results 1 to 10 of 15
Thread: carb cleaner or engine degreaser? (egr related)
    Regular Member gotlosi's Avatar
    hampshire/uk
    Thumbs up carb cleaner or engine degreaser? (egr related)
    if cleaning the egr valve and soliniod am i best off using carb cleaner or engine degreaser? i have plenty of engine degreaser but will i be making the problem worse in the long run using it.
    Regular Member phykell's Avatar
    Apr 2008
    Cheshire
    I'd say it's best to clean it as thoroughly as possible and then apply new grease where needed (the solenoid mechanism). Having said that, I cleaned mine first of all with carb cleaner which is pretty effective but the second time I cleaned it was with paraffin and that was just as good - a quick spray with carb cleaner then removed all the paraffin residue. I found this a more cost-effective way of using carb cleaner which tends to get used up pretty quickly otherwise.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i soaked mine in neat very cherry wheel cleaner and it came out looking brand new
    Regular Member Fruit'n'nut's Avatar
    Thumbs up
    I soaked mine in petrol.
    Regular Member Pete B's Avatar
    Malvern
    Did the valve assembly with White Spirit & stiff paint brush.
    Sprayed WD40 into the solenoid around the rod for cleaning that part, I didn't need to dismantle the solenoid.
    Regular Member ptrehearn152's Avatar
    norfolk
    i cleaned mine in diesel then rinsed of with carb cleaner, diesel is an excellent degreaser and you dont need much, apply with a brush.
    Birmingham
    I used Parraffin on the EGR Valve and Carb Cleaner on the boost sensor!
    Bye bye Vec B
    - Hello Siggy!
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    i used carb cleaner on both EGR and Boost sensor
    Jun 2009
    brummie
    carb cleaner and brake cleaner are the best ones mate
    ta chris
    Regular Member DaveW555's Avatar
    Cannock
    I use brake cleaner, it dissolves most of the crud and the excess evaporates away, any stubborn crud I just scrape off with a screwdriver wrapped in a rag soaked in brake cleaner, brings them up like new.
  1. Carb cleaner while engine running
    By AFA82 in forum General Motoring Chat
    Last Post: 2nd February 2012, 15:06
  2. Carb cleaner
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 7th August 2011, 19:53
  3. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  4. carb cleaner
    By paul.sessions in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 21:02
  5. Replies: 7
    Last Post: 2nd July 2009, 17:51
degreaser to clean egr
engine degreasant clean egr valve
can i use degreaser to clean egr valve
Tags for this Thread
