Results 1 to 10 of 15
Thread: Help!! What brake sizes do I have?
    Regular Member martinbruce's Avatar
    Wales
    confused Help!! What brake sizes do I have?
    Hi Guys,
    Brake warning light came on yesterday.
    Phoned local motor factors and was told that 302's are £66.00 and 314's are £114.00
    Have also looked around the net this morning. I can get EBC disks and pads for the same price (both sizes)
    I have a Signum 3.2 V6 Design on an 04 plate.
    Anybody know which one I have?? 302mm, or 314mm...
    Cheers in advance.
    M
    Regular Member AdeyCorp's Avatar
    Chesterfield
    You have 314mm, as all 3.2 v6 have theses.
    Just wish I had
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    314mm yours are mate
    Quote Originally Posted by AdeyCorp View Post
    Just wish I had
    No they don't, the early elites had 302's.
    An 04 will have 314's though. Easy enough to check - if you look at your front caliper mate, the retaining spring whould be square in the middle. The 302 and smaller calipers all use a spring-type affair which looks nothing like it...
    Quote Originally Posted by Penfold101 View Post
    Yep thats the best way to check, but do check! Just because its an 04 doesn't mean it wasn't sat in a yard for a year somewhere before being plated.
    Very true. To help matters, this is what they should look like...
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    I presume the 314mm refers to the diameter of the disc?
    Yes it does indeed That pic looks like mine, only cleaner
    You should see them since I fitted OEM discs and pads...
  1. brake sizes
    By DAVIDD88 in forum Suspension, Wheels & Brakes
    Last Post: 27th August 2011, 21:44
  2. Brake sizes - 3.0 V6 CDTI
    By Allblackdup in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2010, 22:52
  3. rear brake pads? sizes
    By m3ath3ad in forum Handling & Braking
    Last Post: 21st June 2009, 19:50
  4. Brake banjo sizes
    By installer in forum Handling & Braking
    Last Post: 19th June 2009, 22:16
  5. Brake sizes
    By s1nglef1sh in forum Handling & Braking
    Last Post: 7th January 2009, 13:00
