Results 1 to 10 of 11
Thread: I need help with wiring.
    Full Member gibbon7000's Avatar
    lincs
    Default I need help with wiring.
    Fitted my rear parking sensors today, all went well in the end apart from when it came to the wiring. How do I know which wire is for the reversing lights?
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Trace is through the bulb holder to the multi plug.
    Full Member Teamtom's Avatar
    Vehicle : Vectra C Hatch
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    just dont wire up to foglight, I've seen that done before
    Rubbin'z racing Harry!
    Regular Member hmc_vectra's Avatar
    cupar fife
    care full the wiring is cam bus. read up about it first. dont just cut and tap in to any old wire
    lincs
    Quote Originally Posted by hmc_vectra View Post
    Thats excatly what i'm scared of doing. Does any one have any pics?
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    dont be too scared, the best way I have found is by Backprobing the multiplug to the light cluster with reverse light in.
    with all loom plugged in stick your test light down the back of each wire in the multiplug one at a time whilst getting somone to drop the car in and out of reverse. Make sure your ignition is on. Lighting up your test light when going into reverse will signify the wire you need to take a feed from for your parking sensors
    lincs
    Quote Originally Posted by Teamtom View Post
    Cheers Teamtom, I'll have a crack at that next weekend. Heres a pic of the sensors fitted
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    looks as good as factory fit! if not better,
    Forgot also to mention with your test light, a good opourtunity to make sure the earth point that you have used for your sensor kit, is to earth your test light out on the same point whilst checking for reverse light feed.
    - testing the earth for your sensors and finding you're reverse light feed all in one job, if you see what I mean
    lincs
    Do I need to fuse the wire to the reversing lights from the sensor control unit??
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 53000
    no mate
    as you're only taking a feed, you are still covered by the fuse for rear light
  1. Tow Bar Wiring Help Please
    By countduckula55 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2012, 10:55
  2. Wiring help please?
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 23:13
  3. Sub and Amp wiring help
    By JSYSH466Y in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2009, 12:01
  4. Sub Amp Wiring kit
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 22:32
  5. Tow wiring
    By amiddleton in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2008, 07:57
