Thread: Engine management light
    Norwich
    Default Engine management light
    Vectra 1.9 CDTI SRI
    For the last couple of days when first turning the key the dreaded car and spanner lights up. Immediately on firing up it goes out and does not come on again whilst driving. The car certainly performs as normal and drives as well as before.
    Can anyone offer any advice ?
    Paul.
    preston
    Happened on mine and was the glow plugs
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    When you get the light on with the ignition but goes out on starting simply means the car has stored a fault code. It may just be a transient problem, and would normally clear after a number of engine starts with no fault (30?).
    If it does not clear it will need a code reader to see what fault is being recorded.
    11 Post(s)
    Quote Originally Posted by MysteryElite View Post
    Whenever mine comes on with the ignition but off once the engine is running, it takes approx 30 days before it clears itself.
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Funny you should say that, noticed mine was on yesterday before driving off (1.8vvt), had aircon refilled at kwik fit the day before and this was the first time I'd driven it since then so will wait 30 days. Thanks
    BRIZE NORTON
    I have the same, was told by vauxhall if when started it goes out not to worry about it.
    11 Post(s)
    Quote Originally Posted by F1REFOX View Post
    Correct. As mentioned above, if there is a stored fault code (but no current errors), it will remain lit until the engine is started.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
