Results 1 to 10 of 15
Thread: had a flood!
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default had a flood!
    with all the wet weather the last few days... was on the way back from a day out and the wife commented that her handbag was soakin.. checked the footwell and it was sodden!...
    quick check about the pollen filter and drain hole and it was what you called clogged up..water leaking over the rim of the pollen filter so thats where the problem was!... unblocked the drain hole and there was what you call a torrent of water free'd.. problem solved... although it needs the vax to soak up the water and a new pollen filter!
    Regular Member Avenged's Avatar
    Liverpool
    unlucky mate!!
    hope you get it sorted soon, member this happend to my omega
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Can't believe Vauxhall haven't got a better mod for this problem. This was happening back on the Nova's and Astra's as they too had that stupid rubber drain hose that always clogged up with muck!
    Why couldn't they make it out of plastic so that it would stay open and let the water out? Too difficult i guess!
    Paul.
    Snowman, you got your ears on?
    Liverpool
    Quote Originally Posted by Taffyopel View Post
    Paul.
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    yep you need to check the drain holes regularly
    another quirk from vauxhall
    going to stick a wooden lollipop stick across it to try and keep it open...
    I cut the top off the lid/top of a body spray can (like the top of a boiled egg) fit's a treat & keeps the drian pipe open hth .......
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Volvo V50
    Trim : SE Lux
    Engine : 1.6 Drive
    Year : 2011
    try getting a small piece of overflow pipe and glue it inside HTH
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Paul.
    Quote Originally Posted by neverlandandy View Post
    this happens to a lot of makes of cars,not just vauxhall
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    You will be used to working with stuff that has flaws and has had so for years mate, and no one wants to know do they, Life in a blue suit eh?
  1. Vectra in flood
    By Craig1985 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 1st May 2012, 15:41
  2. Flood water.....
    By signum_1.9 in forum Diesel Engine related
    Last Post: 8th July 2009, 16:49
  3. Drove through a flood, how do I clean the rad now?
    By Chocki in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2009, 14:57
  4. Billing flood watch...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2007, 20:31
  5. Engine flood damage!
    By John Arthurs in forum Engine & Drivetrain
    Last Post: 16th January 2007, 12:35
