Results 1 to 2 of 2
Thread: Front indicator problem
    Regular Member mc_orion's Avatar
    Aug 2007
    Worcester...and most motorways!
    Default Front indicator problem
    How do you go about changing the front indicator bulbs on an 06 1.8sri?
    Also can you get the silvertech bulbs to put in them so i dont have the fried egg look on the front?
    Del
    Regular Member Bethan39's Avatar
    South Wales
    Quote Originally Posted by mc_orion View Post
    Del
    A couple of options remove front bumper giving you easy access to the front lights a 5 minute job removing the bumper or under the bonnet on the airbox side remove airbox giving better access on the water bottle side more differcult just do your best you will cut your hands a bit and yes you can use silvertech bulbs i have them in mine hth someone else might give you better advice though!
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. Rear indicator problem
    By dods84 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2012, 01:02
  3. indicator problem
    By jamie226 in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2011, 08:01
  4. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  5. front indicator light problem
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2009, 10:58
