Thread: Water in the footwells.....
    Jun 2009
    yorkshire
    Default Water in the footwells.....
    Just bought a 53 vec estate. 73 thou miles.
    Its got soaking wet carpets, esp pass side. Not loosing any water from engine , so it should'nt be the matrix. Googled it and found out about the vent under the plastic trim. It was blocked, so i've cleared it out.
    Are there any other places to check for leaks.
    Also, a Vauxhall tech mate has pointed out a slight going into gear problem and thinks its the dual mass......although he's never had to do one in work and is going to check it out on Monday.
    Sometimes it wont go straight into gear.
    Is this a normal fault.
    Thanks for any help.....Andy
    Full Member spennny's Avatar
    Blantyre
    Check the water wells in front of the pollen filter, they will prob be blocked, leaves or something, clear them out and allow the water to escape
    Edit: Didnt read full post, sorry yep i have had a few
    Jun 2009
    yorkshire
    Cheers Spenny.......any ideas on the duel mass........
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    some times my car is a bit hard 2 get in gear mate gets better after 5/10mins runnin
    Jun 2009
    yorkshire
    ok...cheers paul.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    N/S/F wet carpet is most likely the pollen filter drain, as you found.
    Quote Originally Posted by paulvectrac View Post
    been the same on my old pre-facelift 5 speed and my current facelift 6 speed.
  1. Water in the footwells
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2017, 08:01
  2. Water leaking into footwells - new solution
    By boardinbob78 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2010, 08:20
  3. Water pouring into rear footwells.
    By Eirik in forum Bodywork & Interior
    Last Post: 7th October 2010, 20:01
  4. Water in footwells - early warning
    By Ian T in forum Bodywork & Interior
    Last Post: 20th March 2009, 15:02
  5. Water ingress in the footwells
    By michal.lukasik in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2007, 18:25
