Results 1 to 10 of 13
Thread: can aircon be removed?
    chesterfield
    Default can aircon be removed?
    hi
    just got hold of a vecy with slight front end damage
    only real damage is aircon rad
    can i remove or bypass this in anyway?
    cheers.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    you can remove the rad and just seal the ends of the pipe off. As long as its already depressurised. Your not thinking of try to get the aircon to work without the rad are you?
    chesterfield
    Quote Originally Posted by plasma View Post
    i dont need the air con to work .
    so if i remove rad and seal the ends of the pipes the car will be fine?
    would i have to join the two pipes together or just seal each one?
    cheers for reply
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    just seal the end of each one and make sure they are secure and not flapping about and you'll be fine
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    why not get the rad tho?
    chesterfield
    Quote Originally Posted by aerodynamic18 View Post
    the garage said it would be over 1000 pound to replace.
    its free to bypass it haha
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Rubbish - around £120 for the condensor ( rad ) add another £50 if you change the dryer as well. A couple of seals, and a trip to Kwik Fit -
    What you looking at ? Around the £200 mark.
    Quick Google gave this site for bits, but I'm sure there's more
    http://www.automotive-air-conditioni...art=Condensers
    and you too can be:
    chesterfield
    cheers mate . dont know where garage got prices from robbing sods
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    No worries - I rear ended someone in my old Cav a couple of years ago. Needed to replace mine then. Whole repair, second hand bonnet, grill and headlights, new slam panel, AND new dryer and condensor only cost me £250.
    So, if you can hold a spanner I'd get cracking
    chesterfield
    Quote Originally Posted by JagRigger View Post
    cheers for that i will crack on
  1. Have you removed your dpf or not
    By winnie2457 in forum Diesel Engine related
    Last Post: 27th January 2013, 20:55
  2. dpf removed
    By figo1805 in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 16:59
  3. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  4. Should i get it removed
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2010, 23:04
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
