Results 1 to 10 of 19
Thread: fuel filter problem
    durham
    Default fuel filter problem
    could anyone please help.
    a guy changed my fuel filter today when i picked car up it was very sluggish. the aa came out and turned a screw under the fuel filter no fuel drained out you could just here air and gurgling. he couldn't find the problem. when he removed the inlet hose it would not start again. when he left i had a look the inlet hose seems not as tight as the outlet hose could it be this. anyway i pushed the hose in out where it was moving and the engine fired up car is running but very underpowered any ideas would be appreciated.
    vectra c
    02 reg
    2.0 dti
    Bristol
    Vehicle : CDTI 150
    The system is supposed to be 'self-bleeding', this is achieved by starting the car and then running it at a high tick over until the enging runs smoothly.
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    they are not self bleein mate i changed mine not so long ago need 2 bleed the system mate
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Be carefull with bleeding a DTi. The pumps are not up to the task of bleeding the system and a will break if the engine keeps getting turned over. Use a bulb pump or similar to purge the system first.
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    thats what i used john as you say
    durham
    have driven car home tonight could not revs above 3000 and speed above 50mph does this mean system needs bleeding
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    More than likely, just don't drive it untill its bled, the pump is around about a grand to replace
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    i think i would try it mate 2bh its worth a try
    durham
    should i let a garage bleed it as i havent got a clue. do i need to turn the screw on the bottom of the filter. and why would nothing flow out when the aa tried it. would the car drive if the pump was on its way out
    cheers lads
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    yes it would drive if the pump was on it way out if it was 2 brake it wouldnt do out apart from turnin over mate its easy bleed there might be somet on here 2 help bleed it mate
  1. Fuel filter problem
    By jamiedvvt in forum Engine & Drivetrain
    Last Post: 14th January 2013, 15:50
  2. Fuel filter problem
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2013, 11:25
  3. Replies: 19
    Last Post: 30th May 2012, 15:53
  4. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
problems with insignia fuel filters
