Results 1 to 10 of 14
Thread: Front wipers are hitting the a pillar
    hinckley
    Default Front wipers are hitting the a pillar
    I've had my vectra for about 2 weeks now, and i came to use wipers last night. put them on and all you could hear was a clunking as they went up and down. i pulled over and watched them. The driver's side wiper is hitting the a piller as it comes up ( it's chipped the paint) and hits the passenger side as it returns. Is this the linkage problem i've read about?
    comments gratefully received
    Wales, UK
    It certainly sounds like it !! Be wary it doesnt fail completely in the rain !
    Bradford
    Trim : Elite Auto
    Engine : 2.2 Direct Petrol
    Yep, had it on my Vectra too. Sorted out under warranty.
    Regular Member s0501291's Avatar
    Warrington
    Hi
    Do the wiper arms tend to flap about when they are running? in a sloppy fashon? Do the arms park completely horizontally at the bottom of the screen? If they dont park horizontally at the bottom, it could just be that they need adjusting by undoing the nuts on the spindles
    Pete
    preston
    Yes mine do the same, more so at fast speed when you get a whip like action from the wipers due to the speed they are travelling and possibly a bit of play in the linkage. I had the same on my old belmont, the wipers on that car travelled on to the windscreen pillar. I cured it and will have a go at doing the same on my vectra by reducing the sweep of the wipers. i did this by removing the wiper mechanism and reducing the throw on the motor crank by bending it a little. I'll take some piccys when I do it and post them.
    hinckley
    arms seem to park ok, the drivers side hit the a pillar and the n/s wiper as if there is to much play. so this sounds like the linkage problem?
    preston
    Yep linkage I'd go for
    hinckley
    went to investigate this further at weekend. Found there was a fair bit of play in the linkage. I would assume it should be fair tight? i removed the wiper arms to get the plastic off but i could workout how it came away from the windscreen? any put the wiper arms back again and now they don't hit at all which is strange. un-decided as wether to change the linkage or not now
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    they are on a tappered splin so might of been slightly loose, so now you have tightened them up might of done the trick
    Jun 2009
    KINGSWINFORD
    This happened to me in France last year. Blades hit the frame and then the mechanism failed. Single pin pressed into plate and drives both wipers. This had come loose and altered the degree of travel on the blades. I disconnected passenger side as an emergency measure but access was difficult. Very stressful in pouring rain on French road. Replacement has been redesigned with 2 pins on plate. One for each wiper. Cost about £200 I seem to remember.
  1. Need tints B pillar to B pillar...anyone know of anyone cheap near Reading?
    By wingz123 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2011, 11:55
  2. front wipers gone mad
    By tomcat1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2011, 21:33
  3. front wipers.
    By Marty J CDTI in forum Bodywork & Interior
    Last Post: 1st September 2007, 22:24
  4. FR 1454: Front door area B-Pillar - Wind noise (Vec C)
    By Duncan in forum Body & Body Equipment
    Last Post: 25th June 2005, 15:32
vectra sloppy wipers
