Thread: Help please - urgent advice needed
    Nottingham
    Default Help please - urgent advice needed
    Driving up M1 tonight, felt like a massive impact driver's side but on close inspection the vehicle is much lower than normal on that side (having now been recovered home)
    What is it likely to be? Spring or what? Any suggestions as to repair costs?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Probably the spring broken and jumped out of the seating. Great time to fit some eibach's
    Regular Member Cossy's Avatar
    East Yorkshire
    Definatly sounds like a spring or even the shock, perfect time for some eibach and bilsteins! :>
    Regular Member kns's Avatar
    Northampton
    Mileage : 000
    Yes sounds like a broken spring to me too. See if you can see any broken spring in the seating cup. ( though it is probably on the M1 having fallen off).
    Nottingham
    Thanks folks - are new springs easy to fit. never done owt like this in my life.
    And I gather the pro-kit drops by 30mm? Any implications as mine is an estate? Would the drop affect the use of snow chains?
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Changing the springs can be a dangerous job, if you do not have the correct tools. Ask around if someone has the proper tools before you try to do by your self....
    Regular Member Robbie69's Avatar
    spring for sure!
  1. urgent advice needed
    By chrissri82 in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2012, 13:01
  2. URGENT Advice needed - Injectors
    Last Post: 20th March 2009, 09:23
  3. 215/50 17 Tyres Urgent Advice Needed
    By aaruck in forum Handling & Braking
    Last Post: 12th November 2008, 23:44
  4. URGENT ADVICE NEEDED! Tech 2 hasn't worked and costs rising
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2007, 20:30
  5. Some urgent advice needed please...
    By Kev_A in forum General Chat
    Last Post: 18th December 2006, 22:07
