Thread: squeaking brakes
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    Default squeaking brakes
    it sounds squeeky when driving but if I brake it stops also only seems to do it at slow speeds does it sound like pads need changed or sticky caliper wheel doesn't get hot unlike it did on me vec b I had
    Regular Member david.aka.judas's Avatar
    Suffolk
    oh - I'm so sick of mine doing it....
    I'm going to take the pads out and copper slip them.
    or get my garage to do it......lol
    me to people look as u pass so I have to keep appying brakes to stop it a few seconds
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    my salvage one sounds like a steam train pulling into a station, really gotta get a new set of front discs.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Are they cheap pads? I had this same problem, tried to coppaslip them but had to replace them in the end
    Suffolk
    yeah - mine are.
    mine are gm so prob cheap chat LOL
    Regular Member Cossy's Avatar
    East Yorkshire
    Have had the same problem in the past, ended up being the calipers needed stripping an a good cleaning and copper greasing up. Give it ago before you spend your £££.
    Regular Member bushygrunt's Avatar
    Wakefield
    I use EBC red stuff pads, amazing stopping power and very little noise, they dont spit out as much brake dust and your alloys look cleaner for longer.
    Regular Member cheekylemon's Avatar
    Aug 2007
    Droitwich - Worcestershire
    I had a similar problem, except mine was more of a screech and was REALLY loud.
    The noise never happened when reversing, and in the end I took the wheels off to have a good look.
    A tiny little stone was sat in there. Noisy little sod, but I'm glad it was a quick fix.
    Hope yours is something as easy to remedy.
  1. aux belt squeaking.
    By john1 in forum Engine & Drivetrain
    Last Post: 21st April 2009, 20:32
  2. Squeaking from cold
    By Marky in forum Engine & Drivetrain
    Last Post: 15th July 2008, 13:01
  3. squeaking from brakes part 2
    By baz2003uk in forum Suspension, Wheels & Brakes
    Last Post: 29th August 2007, 08:19
  4. squeaking from brakes
    Last Post: 12th August 2007, 23:28
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
