Thread: Blown bulb warning light
    Regular Member Ant S's Avatar
    Ashington
    Default Blown bulb warning light
    Hi I've ahd the bulb warning light on the dash for weeks now, I have checked all lights are working even the door and boot lights and all are ok - is there a way of switching this off? I am sure there was a trick for this??
    Any help appreciated
    many thanks Anthony
    Full Member spennny's Avatar
    Blantyre
    I had this mate, eventually found out it was the actual cluster that was at fault, rear left clusters ,
    Mileage : 000
    Give it a bit longer then you will find a blown bulb. I have found this out myself.
    Regular Member Swaite53's Avatar
    South Wales
    If a rear tail/brake light goes, it automatically switches to the other working bulb, so at a quick glance can look like there isn't a problem. Check to make sure that the same bulbs are lit on both sides of the vehicle.
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    I had same problem but was told same thing bout bulbs I checked them all and sure enuff 1 was dodgy all lights still worked sorted now thanks to advice off lads on here
  1. bulb warning light on....but no bulbs appear blown
    By rjw in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2010, 01:18
  2. 05 Vectra CDTi - Blown bulb warning light?
    By gmc in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2010, 21:29
  3. Blown Bulb Warning...
    By VikBee in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2009, 17:46
  4. Blown Bulb Warning Help??
    By Jolly in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 00:15
  5. Blown bulb warning light on dash??
    By Genterz in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2008, 11:10
vauxhall vectra bulb warning light is on but no bulbs are blown
vauxhall vectra c bulb warning light staying on I have checked all the bulbs they all working
