Thread: Gearbox Oil Change
    Regular Member Jezzy's Avatar
    S.E
    Default Gearbox Oil Change
    Has anyone on here done a DIY oil change on an F40 gearbox? I'm thinking of doing it, as Haynes reckon it's not too hard: remove battery, remove battery cover, under which you find refill point for gearbox oil, remove sump plug and drain the old oil out, replace plug and fill gearbox with exactly 3.2 litres of new oil.
    Does this sound accurate or have I missed anything difficult/major?
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i think i would take it 2 a garage mate
    Admin plasma's Avatar
    On the Forum
    322 Post(s)
    Engine : 150
    Mileage : 74000
    theres a thing where if the gearbox was hard to engage 1-2 when cold but 3-4 when hot they'd drop the gearbox oil to 2.3L from the 3.2L which it contains. Not 100% sure about the symptons but i defo recall this as a field remedy
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    S.E
    It's a little bit rough from 2 to 3, but that's about it.
    S.E
    Quote Originally Posted by paulvectrac View Post
    Where's your sense of adventure mate?
    But being serious, it would have to be a Vx dealer, a generic garage might be too casual and top it up with as much as it will take, rather than the precise 3.2L that it needs, or use the wrong grade of GM transmission fluid, etc etc.
    On the Forum
    322 Post(s)
    Engine : 150
    Mileage : 74000
    Complaint: Hard 1-2 shifting when transmission is cold, 2-3 shift when transmission warm
    The reduced oil level was introduced in production starting 08.05.07 with the following VIN:W0L0ZCF4871102355
    In case of customer complaint reduce oil volume from 3,2 to 2,4 liter.
    Note: If the shifting behaviour will remain unchanged we do not
    recommend a transmission replacement because the problem might reoccur
    since there were no relevant design changes since
    transmission-No: R05020418 (March 2005).
    S.E
    Thanks Plasma! I also have trouble finding 7th gear sometimes...
    On the Forum
    322 Post(s)
    Engine : 150
    Mileage : 74000
    nothing i can do for 7th, but i could sell you something if u like
    S.E
    Quote Originally Posted by plasma View Post
    Something tells me you're not referring to a ZF 7-speeder autobox
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. M32 gearbox oil change??
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 20:51
  3. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
